Acer XB271HU Replacement
phorkz
Hi guys,
I am still rocking a XB271HU and wondering what upgrade path i should be taking, if any at all?
- 10700k 5ghz all core
- Asus 3080 TUF OC
I do like the higher refresh rate, so not sure if i want to go to 4K, or just stick with 1440P. Also GSYNC is a must.
What do you guys suggest i do? What are my options?
Nothing to be gained by changing this monitor for you.
This model has real G-Sync with good overdrive and BFI. Also sRGB native panel this sharper font rendering than DCI-P3 with sRGB emulation.
As for DCI-P3 - the only way to actually use it is with HDR and HDR in monitor situation is currently pathetic and anything you would want to enable it is prohibitively expensive and still falls short of what HDR should be.
Thank You
I agree. Unless you want to go 4k, you're on a great panel already.
Reactions: steal
