I'm starting off a build using:
MSI 785GTM-E43 mobo
Phenom 2 BE 555 cpu
AC Freezer Pro rev. 2 cpu cooler
OCZ DDR2 PC 6400 2x2 GB
Galaxy 9500GT video card
WD 640gb hard drive
Corsair 400w ps
Coolermaster Elite 335 case
I thought this was gonna be a fast, straightforward build, but right after plopping my cpu in the socket, I ended up scratching my head. All of my after market coolers have utilized a front-back (west-east) alignment of fans. Looking at the directions for the Freezer Pro, there seems to be a top-bottom (north-south) fan configuration here. The mounting brackets provided by AC only mount on the top and bottom edge of the mobo's cpu bracket. When the corresponding brackets on the heatsink itself are connected to these mounting brackets, the fan is left in a north-south configuration. There isn't a separate bracket to replace the original mobo bracket to allow for a west-east fan configuration. The only bracket provided is for mounting an Intel cpu.
Am I having a brain fart here and missing something obvious?? I checked their website and it's completely useless. The "installation" help is the same shitty set of diagrams that came with it in the first place. I can't imagine why they would want the heat coming from the cpu to be directed up to the power supply intake or down towards my video card.
Thanks in advance for any helpful hints or tips. Hopefully I'm just missing something obvious.
MSI 785GTM-E43 mobo
Phenom 2 BE 555 cpu
WD 640gb hard drive
Corsair 400w ps
