AC Freezer 7 Pro $22 Shipped
Not a bad cooler, though it can get loud at 100% RPM, though it's still not all -that- loud.
I use Speedfan to keep it at about 75%, which is fine by me.
Works fine. Although in most cases, if youre not overclocking, the stock cooler works just fine too.
Try telling that to my eardrums. :p Q6600 B3 @ stock EVERYTHING, you can hear it clear across the house during 100% load (read: all the time from Folding). Opening up my case in the next few days to swap in either a Ninja or a 9500, thank goodness.
i was just looking to buy one of these...thank god i waited
THANK YOU SOO MUCH
yes, ACF7 is overrated, its loud and horrible push pin installation... thats why I sold mine and bought an Asus Silent Square instead
you're welcome everyone!
and to you I believe he was referring to his stock cooling being loud
Actually worked on a tower that had a fried CPU that used on of these. It wasn't the coolers fault more like someone not making sure it was all the way secured and because of the top heavy it hung off the CPU. It was funny because no one could figure out what was wrong with the computer, everyone always looked at it when it was laying on its side, finally when I saw a friend checking some wires I saw that his hand was bumping the fan and it was loose.
I had one of these on my E6600 running 3.3Ghz with good temps. Definitely a good deal.
hahaha, that's one thing I hate about the push pins...
just to say how good the stock cooler is compared to the FP7...
i bought the FP7 a month ago, and actually returned it. my Stock intel HSF gave me near identical results, even when doing a mild overclock.
sure it looks much better than stock, but for 20$ if its function isnt any greater, id buy something else.
you apparently have horrible skills when it comes to HSF installation then
you also may have used crappy TIM
and finally many TIMs' performance greatly increases after they are broken in
I use one of these myself, E6600 @ 3.2Ghz, 39/40c idle, 51c load max with around 25c ambient temps.
that's not bad, it's not that this is a spectacular cooler, just at $22 the price/performance ratio is great
i very much doubt my skills are lacking. Amazing how thats the first thing you question too. I was just commenting on how similar it cools my e4300 compared to stock.
oh and, i doubt that AS5 is crappy TIM.
greatly increase after time? maybe marginally, not great though
e4300's run very cool at stock and mild overclocks. It is normal to have only small improvements using a FP7 compared to stock HSF. Even the pre-applied TIM on FP7's are very close in performance to AS5 so that's unlikely the issue.
What you have is just the expected result from a very cool running CPU. The performance gain will increase as you push the overclock closer to the limit (as is the case with all decent coolers compared to stock) but as others have pointed out above, the FP7 is horribly loud at full speeds. My e4400 at 3+ GHz is cooled fine at low settings on the FP7 however, again showing that these CPU's are just cool CPU's except at the upper limits of overclocking range. At mild overclocks I doubt there's a big advantage of ANY cooler over stock on these CPU's.
idle temps of about 44c and load about 65c is cool? seems a little on the high side for the load
Is it possible to replace the fans on this cooler? I always wondered that..I want it as quiet as possible so I would like to stick a nexus or something on it...
Doesn't look like it. The fan is built into the heatsink housing IIRC.
Where are you getting 44c idle and 65c load from?
"Once the settings have been changed simply exit and save the settings in the BIOS and then wait for the system to re-boot with that magical 3.00GHz clock frequency. Our idle temperatures with the standard Intel box cooler went from 34 degrees to 41 degrees. Under load the system reached 49 degrees, though this is nothing to be concerned with."
LegionHardware
http://www.legionhardware.com/document.php?id=642&p=1
Overclocked to 3 Ghz which is not stock or mildly overclocked, they're getting 49C at load. Non-overclocked they're idling at 34C as well, which is similar to what I've been getting - 31-35C range on stock intel cooler idles.
Yeah. The fan was built to fit on the heatsink. Without putting a fan on their yourself (zip ties, anyone?), you can't simply swap the fan out for a different one.
