About to upgrade- Would like opinions
Jeeprs69
I'm a beginner so to speak. I have a X2 4800+ sckt 939 on a Asus A8N32sli, XFX GX260 Black edition. I've been looking at upgrading. here is my plan so far-
Q9550( I like the 12 mb L2) or maybe a Q6600- I've got a Zalman 8700( I think I still have all the brakets) but will the stock CPU heatsink work for now?
Gigabyte GA-EP45-UD3R or
Asus P5Q Pro
Patriot Extreme Performance 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16820220314
Or
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231226
Will probably buy later today
Mostly gaming- L4D,Far Cry2,Crysis,2142,Combat arms,and web surfing. Dvd copying,cd burning etc
2) What's your budget? Are tax and shipping included? I'd like to stay around the $500 mark
3) Where do you live? Dallas Texas!
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
CPU Mobo Ram
Got Antec 650 true power, XFX GX 260 Black Edition, X-FI Xtreme Gamer sound card,Antec Case(don't rememeber model#) Raptor 150, One SATA DVD one IDE
6) Will you be overclocking? Wanting to learn how- but not at first
7) What size monitor do you have or plan to have? 22" LG right now. Will go bigger when I get more money LOL
8) When do you plan on building/buying the PC? ASAP- this weekend
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc. Don't plan on going SLI- know nothing about raid, have no firewire stuff..
Either the Gigabyte GA-EP45-UD3R, GA-EP45-UD3P or Asus P5Q Pro are good choices for a motherboard.
The Q9550 is, at most, 10% to 15% faster than the Q6600 yet costs about $130 more. The Q6600 doesn't use that much more power than the Q9550 but both CPUs are great overclockers. Just figure out whether or not you want spend that extra $130.
RAM wise, it all depends on your CPU. For the Q6600, all you need is DDR2 800 RAM. For the Q9550, DDR2 1000 RAM and above is a good choice. If you do go with the Q9550, I recommend this RAM set since it's only 66Mhz slower, comes with free shipping and is cheaper than the Patriot RAM you chose:
G.Skill F2-8000CL5D-4GBPQ 2 x 2GB DDR2 1000 RAM - $50
Yah... what Danny said.
If you mostly game, go with the Q6600 (and DDR2-800 RAM) and OC it to at least 3.2Ghz. You can probably do 3.0Ghz on the stock cooler, but I wouldn't recommend it. You should definitely look into a 3rd party HSF, like the Xigmatek HDT-S1283 + ACK-I7751 to push that Q6600 to 3.4-3.6Ghz. ;)
If you want to save even more cash, check out the UD3LR and the DS3L instead.
this is what I bought-
Q9550
P5Q Pro
I shouldn't have any trouble running a single 260 vid card in this board will I? Since it is Crossfire and my card is Nvidia?
Ok got it up and running. LIKE THE WIND! It literally Doubled my frame rates in the Far Cry 2
benchmark. I went from
* Average Framerate: 23.63
* Max. Framerate: 41.27
* Min. Framerate: 12.33
to
* Average Framerate: 62.10
* Max. Framerate: 87.73
* Min. Framerate: 47.74
Nice increase
Nice!
Now's where are the pics of this upgrade? :D
ask and you shall recieve
before
Middle
Almost done
Holy dust batman.
You kept the 939 system just as it performs now a days. :p
Nice upgrade, the same im running, well before a corsair psu decided to take my q9550 and gtx 260 to rma heaven. Only problem i see is the cooler, but if your doing low overclocks, which for the Q9550 range from 3.0ghz-3.6ghz, you should do fine. If heat problems persist, do what i do to my 64, and use rubberbands to strap a 120 on there :cool:
Holy dust batman. Gotta love living in the country. I take all our puters apart and clean em every few months. Thinking I may need to do it more. LOL
Nice upgrade, the same im running, well before a corsair psu decided to take my q9550 and gtx 260 to rma heaven. Only problem i see is the cooler, but if your doing low overclocks, which for the Q9550 range from 3.0ghz-3.6ghz, you should do fine. If heat problems persist, do what i do to my 64, and use rubberbands to strap a 120 on there :cool: right now, it's running at 17C. GPU is 43C System 27C according to Speedfan.
I did run my last one with the sides off. I have now put the case together to help hold down SOME of the dust.
The Fan in the back is a 120 Brushless and it MOVES some air. I have a intake fan and can add one more on the side. But I don't know which way the one on the side should blow? Out or in?
AND if I figure out how to overclock and do it, I'll be getting liquid cooling and a new case.
Noise.
At what area is the side fan gonna be around? Meaning near the vid card, cpu, etc
Aight heres a 3 year old diagram of your airflow, i might be missing a fan i don't see.
Clicky
As for the side fan, if its around the gpu area, you can help it disburst the air that comes out the side grill by using that fan as a exhaust. Placing a fan in the 2nd (Hd cage from what it looks like) might help cooling a bit more towards the cpu, Since the front bottom intake are going directly to the video card.
Edit: Or if theres a bracket or fan holes on the top of the case, use that for an intake for more air towards the artic cooler, Since the psu fan is acting like a exhaust as well. Mind me asking for what your load temps are? You running stock at the moment, correct?
All this mumbo jumbo is prob bad since your temps are fine as it is.
the fan is over the CPU area.
Running Crysis 1680x1050 crap forgot the settings.
Speedfan says:
GPU 75C
CPU 25C
Sys 39C
C0 44
C1 44
C2 39
C3 37
Is that a little high on the vid card?
The highest i have seen on my 260 has been 66C so its fine, but im sure a bit more air can lower that.
You might wanna try a mod i did, which was put a 120mm fan on the pci expansion slots (outside) to help the air disburst faster, i noticed that the air was slowly moving away from the area. Keeping the back of my case hot. Another thing is to remove the 2 expansion slots surrounding the video card, that also dropped my temps a few degrees and noticed alot of trapped air moving out.
probably as an exhaust, since the sides releases hot air as well. Might help remove any hot air spots if there is some.
Try it out, and see if you see temps drops.
Temp probes from an old lcd fan controller, might not be a good tool for the job but it did for me. The hot spots i found on my rig like i said was under the card and top, near the pci expansion slots, which was fixed by opening it to let the hot air escape, and also a quiet 120mm fan. Dropped my temps on the 260 to under 60C at certain times.
The thing thats kinda iffy about my results is room temp, sometimes my room will be 60F, and others it will be around 30-40F
ok I installed EVGA;s Precision. It said the fan was set to auto at 40.
SO I used that Precision to speed it up and now after playing Crysis for a long time- arounda hour. GPU is 60C
60C is still a good temp. Those cards are rated for 100C use IIRC. So you're well under the thresehold.
