about motherboards fitting in cases
like my name says, i am a complete and total nooblet. anyways, i was just wondering, i plan on building my first computer, and i was just wondering, wil this motherboard
http://www.newegg.com/Product/Product.asp?Item=N82E16813127152
fit in this case?
http://www.newegg.com/Product/Product.asp?Item=N82E16811144001
the back of the motherboard doesn't look like the back of the case. they don't line up. will this be a problem? also, i looked around and all the motherboard backs look the same and the case backs look like all the other case backs. as in, all the mother boards look like they won't fit into any case.
can anyone inform me if the motherboard WILL fit into the case? if not, then can some1 give me a link to a case that the motherboard will fit into?
actually, i was also considering this case
http://www.newegg.com/Product/Product.asp?Item=N82E16811156140
and motherboard:
http://www.newegg.com/Product/Product.asp?Item=N82E16813135152
will those 2 fit together?
It will fit. Cases and motherboards come in standard sizes. The case supports ATX (and microATX motherboards), and the motherboard is ATX. That's what you're looking for.
great, i figured it would fit but i wanted some1 who actually knew something about motherboards and cases to tell me whether it will fit or not. thank you and long live [H]ardOCP
It will fit since they are both ATX as above but the stuff on the motherboard won't line up with the case. Fortunatly thats why most all motherboard mainufacturers will include a custom I/O plate so there will be holes for the firewire, usb, etc.
While there are no guarantees in life, that MB and case is a pretty safe bet.
The old I/O shield should just pop off with a well-placed blow from a blunt screwdriver :D.
The rear IO plates may differ, but if you look at the pics for the motherboard you will see that it comes with one designed to fit your motherboard, the one in the first case you listed is just pooped into place, however in the second case you listed, the Raidmax, you will have to cut a couple very small slivers of metal that hold in the stock IO plate, that will leave you with the correct sized hole to pess the plate that came with the motherboard into. all you will need is a pair of wirecutters as the slivers of metal holding the rear pleate are very small and easily cut with the wire cutters.
