abit nf8 installation problems
matt00926
I installed my new abit nf8 motherboard today with my 2800+ 754 retail. It all went smooth until i tried to plug it into my power supply. Im using an Antec sonata case with a 1 fan 380w psu. It has 20 pins for the psu connector. The motherboard has 24 pins. I looked in the manual and it says this board is compliant with 20 pin psu connections. So i thought great and i plugged it in. I also plugged in the small square 4(i think 12v cord flawlessly. Instead of the bottom four being unplugged, the top four are left unplugged , and it doesnt fit any other way
The problem is that the little black clip that is supposed to clamp down onto the white clear plastic part on the motherboard to keep the cable steady into the board does not match. The black part on the cord itself is further down the cord and does not slide down onto the small plastic part on the motherboard connection itself. This makes it so that any slight jiggle of the psu cord makes the cord come out. I am pretty sure the powersupply is comptabile, is this just one of those weird issues? Im wondering if i would be safe taping the wire down to hold it in sturdy or something of the sort?
I am frustrated so im just leaving it sit until i can find out for sure because i dont want to ruin anything. Im at college and i am going on break tomorrow so i suppose i could bring up a different power supply with me and try it but id like to have it set up before i leave for break.
Edit : ive also tried connecting the power cord many different ways and this is the ONLY way it even fits in, yet its still loose
I don't see why taping the ATX connector would be a problem. If that doesn't work, you could always get a 20-24pin adapter for like $10.
Took your advice and ordered a 20-24 pin adapter from xoxide for 3.99 totalling 8 dollars shipped. kind of a pain in the ass i cant use my computer for a few days now oh well im on spring break :cool: .
haha...have fun.
I haven't seen any of the old nf3 250Gb chipsets with 24-pin ATX connectors. So, I can't see why the adapter wouldn't work fine for you. Enjoy.
