misfitsfiend
- Jun 18, 2003
so i have finally gotten my computer up and running, and now there's something new that i can't figure out. i just set up my computer with an abit nf7-s, and mobile barton 2500+ running @ 2.4ghz with 200fsb x 12 multiplier. i've just decided to run some diagnostic tests, and i decided to try the included ABIT EQ program that came with the motherboard. whenever i boot it up, 2 high and low pitched beeps come up, almost like a siren. it sounds like some sort of warning or something and it says cpu rpm
ff, cha rpm
ff and power:1622 . i'm fairly sure my hsf combo is not to blame here, because it has been running without crashing at all. after hearing the beep, i figured maybe i put the cable in the wrong place, which i had, and it STILL didn't fix the problem. ALSO, the psu fan monitor is plugged into the correct place and THAT doesn't show up either!
thanks in advance for all your help!
