Abit IP35 pro SATA setting question
Zorachus
In my Advanced Chipset Features; under SATA mode, I am running just one 1 RaptorX 150gb hd, but what setting should I keep this at in Bios ?? IDE, RAID (no), or AHCI = Advanced Host Controller Interface
IDE is fine.
If you wanted to run AHCI (no real advantage atm imo) you would have to do a reinstall.
No, you don't have to reinstall. But you may have to do some acrobatics. The AHCI driver refused to install without an AHCI drive being present, and you can't boot into an AHCI drive without a driver, which is something of a catch-22. Theoretically, you could do a repair install, but the Windows XP disc refused to boot up on the crappy JMicron Parallel ATA IDE controller (and I don't have any SATA or USB optical drives). So I connected my XP drive to a JMicron SATA port (which works perfectly fine BTW), set the Intel ports to AHCI, booted into XP, installed the Intel AHCI drivers, and moved the drive back to an Intel SATA port. Now XP is running great on AHCI, no reinstall needed.
So, how did you install XP in the first place and when you added the ACHI drivers?:confused:
What difference does the ACHI drivers make? :confused:
AHCI allows you to do things like SATA hotswapping and using NCQ if your drives support it.
I had AHCI enabled for my Intel SATA ports on my IP35 Pro, but when I added my Hitachi T7K500, Vista and the mobo had an absolute fit with it, so I set my Intel SATA ports back to IDE mode.
I installed XP in the first place when I still had my MSI K8N Platinum/SLI (nVidia nForce4 SLI socket 939) motherboard. ;) The XP disc has no problem with the nForce IDE. That also is why I couldn't merely reinstall XP and had to salvage my old one (which is better anyway; I don't want to take the time to reinstall all my apps!) When I bought the Gigabyte GA-P35C-DS3R, XP booted up just fine in Legacy IDE mode, but some Linux distros seemed to be accessing the hard drive slow in that mode, which is why I changed to AHCI in the first place. Now that I have the XP AHCI drivers in place, both XP and Linux are working with no problems whatsoever.
