I've been running this setup for quite awhile and this morning while turning on my computer the BIOS hung while checking the memory (no keyboard response, Under the CPU info it only says "Memory Tes", hangs for 4-5minutes, and then resumes normal.)
And that hanging happens with only one stick in, when I had two sticks in it hung, but having seen this problem start with two I took the 2nd one out fearing it could just be my memory. I should go test and see what the time is with two sticks... either again 4-5 min or longer.
What do you think this could be? Board on it's way out? Memory? I have some extra slower/shittier DDR2 but w/ questionable access to my BIOS I'm not sure if it will detect this other memory's lower settings.
Does ABIT still take RMA's? (lol, I know they're gone pretty much, but)
The diagnostic screen on the board is also at # 25, which basically means it's testing the memory from reading the manual.
