Helping a friend build a new system and am confused about the 8pin and 4pin CPU power connectors.
OK here is what I found in the Abit FAQ....
http://www.abit-usa.com/products/mb/faq_popup.php?model=326&faq_id=759
However, I still have a question. The power supply is a Cooler Master which is a 24pin ATX with an additional 4 pin CPU connector. The extra 4 pins on the 24 can be detached and not plugged in. So after looking at the FAQ, I should disconnect the extra 4 pins on the 24 and NOT connect it, while aligning the 4pin CPU power to the far right of the 8 pin connector.
Is that correct, or do I still use the extra 4 pins of the 24 as well. (To connect or not connect, that is the question.) Did any of that make sense?
