Abit AN8-SLI Fatal1ty
knight3058
I got this system with 1GB of Kingston Hyper X-A RAM, Venice Athlon 64 3000+, Geforce 6600GT OC (x2), I got this system with the intention of having a system that I could upgrade gradually over the course of at least a year, but the system keeps rebooting randomly. I've tried manually setting the memmory, ran memtest86 for 37 passes (no faults), I keep getting physical memmory dumps at random times associated with http.sys (every time). Any ideas?
Soul.Survivor said:
sounds like software to me.
Could easily be a PSU problem too. We need more information on the system. As well as driver versions before making any clear diagnosis of the problem.
Windows XP Pro SP2
Nforce driver 6.28 (I think), Not 6.66, and not the one on the CD...that made it crash almost immediatly.
Video driver pre 7x.xx series. (68.88 or something like that)
System works better with the IDE drivers from nVidia than the MS ones.
I have a 200 GB PATA Maxtor drive & a 250 GB SATA Western Digital
Antec NeoPower 480 PS
Case is a KingWin with 5 80mm case fans.
Currently I only have 1 Geforce 6600GT running in the system as the other went out for some reason(according to BFG, they have to have the same BIOS rev in order for SLI to work).
I'd go with 6.66 for the chipset and 7.77 for the video, if not the 78.01's. Why on earth are you running such old drivers? Doesn't make sense to me.
You might want to run Driver Cleaner on the machine and clear all your nVidia driver files. Then load the above mentioned driver versions. Start with chipset drivers, then move on to video.
I like the 6.66 and 78.03 beta drivers. What do you mean it runs better with the nvidia ide drivers? I would also try running only 1 hard drive, if it still happens install windows on the other one and try it.
I was thinking spyware but after searching the interweb for http.sys and reboot I came across a link to another forum, about the 5th link down, took like 10 seconds to find, where they solved the problem (imagine that).
So, it's probably either your network drivers or the network "card" itself. I'd update to the newest nvidia drivers and if that doesn't fix it put a NIC in there and then RMA that board when the add-on NIC solves your problem.
I'm so sick of everyone saying everything is a PSU problem though. It seems like every thread where someone is having trouble somebody has to chime in with the "it could be a psu problem". No offense, and sure, it COULD be a PSU problem, but it's probably not. I blame the guys at the DFI forum for this because if you don't have one of the 6 or so "A list" power supplies then some guy has got to come in and give you a link to the "WHY YOU SHOULD ONLY BUY ONE OF THESE POWER SUPPLIES" bs thread. They don't even respond to the problem, just a general spend some more money so we can eliminate your PSU as the source of the problem even though the evidence you've given us has absolutely nothing to do with a power issue. They need to be saying "our boards have horrible power regulation and therefore you have to use a top of the line power supply to make up for the fact that we can't build a stable, reliable motherboard"</rant>
Found this in another forum. Hopefully this works.
"Your problem is caused by an MS issue -- They played games with HTTP.SYS which screwed over pretty much every firewall out there.
You need to disable the windows service 'SSDP Discovery Service'
Start --> Admin Tools --> Services --> SSDP Discovery Service
Disable the service, reboot. Done, no more IRQ NOT LESS THAN... crashes.
Supposedly MS addressed this in a recent update. Don't know, don't trust it enough to enable the service again.
NVidia Moderators PLEASE STICKY A MESSAGE WITH THIS CONTENT. This error accounts for a huge number of posts in this forum.
Not like they read anything in here that isn't 'Reported' for inappropriate content anyway."
I just wanted to clarify that reboot problems RARELY are power supply problems...most are software or memory. The only time many reboots were caused by power supplies was back in the AT days....not ATX.
I have the vanilla AN8-SLI and I have occasional problems with rebooting too with 2x1GB sticks (Crucial Value UCCC chips).
These boards are notorious for having problems running 1T with different memory types and memory controllers. Awesome memory controllers (FX-grade, pretty much) and quality RAM usually allow it, but it's extremely picky with anything else. The 17 BIOS clears this up somewhat by using a slightly altered RAM table at a performance loss, but some people will still have problems if their processor doesnt have a 90% perfect mem controller.
Maybe I'll try running in 2T mode and see if that helps me any. Funny that memtest will pass continuously, but WinXP won't load at some timings.
In that case, the problem is with your memory controller then. And, instead of running default test conditions when you do use memtest, you're better off doing runs of test 5 and test 8. These more closely mimic windows usage, and also test the largest amount of RAM of all the tests. Just a note...
