Abit an8-sli fatal1ty perhaps causing system stutter?
theCOMPANY
First off, i hope this is the right spot for this, as i am a newb here.
System:
AN8-SLI Fatal1ty
AMD64 Opteron 144
EVGA nVidia 7800 GTX
Sound blaster Audigy SE (to be explained...)
2x 512 Corsair Value Select ram (not sure model numbers or anything like that, it was a Christmas gift 2 years ago)
WDC WD120BB-00CAA1 (hopefully this means something more to you than Western Digital 120gig hdd...)
not sure what else you may need...
So, i'm not really that computer saavy... so bear with me.
Every time i update drivers (video, mobo, audio.. anything) i get a system stutter. Its mostly noticeable in music and games. Music gets choppy for a fraction of a second about every second. Just like a pin-prick in the sound. In games it stops for a frame every second or so. Its also noticeable if i just shake the mouse back and forth but thats a bit harder to tell. The only example i could get of this would be a sound clip i recorded, but it sounds normal on other computers, but here it is anyway:
http://h1.ripway.com/Iamthecompany/soundproblem.wav
I've gotten the problem fixed in the past, but it always seemed to just sort of fix itself. There was never really anything that i recall doing that was a deffinite cure for it. It happened with the Realtek card the board came with, so i dashed out to Best Buy, got the cheapest card they had (hence the Audigy SE for $35) and that seemed to fix it, but then after the format i just did yesterday, its the same thing.. so i'm thinking its the motherboard since it had the same problem with two different cards.
I've googled every way i can think to phrase this problem and haven't come up with anything. If i need to get a new board (which i'd like to avoid, as this was sort of expensive, and a Christmas gift) what would be reccomended for $100~? But even better, any ideas on how to fix this problem?
do you have the nvidia ide driver or the firewall installed from the nvidia chipset driver package both have been known to cause issues,no need to have a sound driver from the nvidia chipset package installed either with a pci sound card
nope, neither of those are installed. I've tried this with both the nvidia sound driver and without and it still does it.
i know i downloaded and installed it, but if i have to manualy enable it, i don't recall doing that.
lol @ the n00bie
That out of the way, I had totally forgotten you had thew Audigy. You didn't install the nfroce audio drivers when you formatted, did you?
EDIT: Helps to read doesnt it? :cool: My only other suggestion, as I already laid out to you, would be to swap out our motherboards, but that is a mucho pain in the ass.
yar, and with working Hot Topic now i dont know if i work sundays... we shall discuss this matter further.
Because the goth crowd all goes to church on Sunday or what? Harrrrrr..
:(. I forgot about hot topic. It's going to be a bitch finding a day were both off.
No.... but I'll go ahead and fill you in on the situation. He used to work on job at Borders, in which Sunday was one of his days off. Typically, one of mine also. Now he has to be a shitty mcfuck and work two jobs, so sunday may no longer be open. Being that he lives about an hour and twenty minutes from me, and it could be a timley project anyways, we'd sorta both need the day off to get anything done.
You're killing my joke with the whole explanation thing, I hope you know that.
actually, the reason i usually have sundays off is because of church, but now my church is on Thursday and the twats at work won't give me Thursday off.. because they rule like that.
However, i might not work sunday, i'm not really sure what days they have me scheduled. Tomorrow i only work 2 hours, and i'm out by 1.. so if they do that on Sunday i could drive out to mchenry.
i knew you were joking.... but i figured i'd explain anyways
cool and quiet is in the bios under power management and would be enabled by defualt although does little without the driver installed but if you did install the driver you could try turning cool and quiet off in bios to test for the stutter issue fix
have you tried the just released recent amd dual core driver
It's not cool and quiet... i can assure you that... and having a single core CPU, the dual core drivers aren't gunna get him far either :D
disreguard the dual core driver suggestion and maybe do the motherboard swap for a test
Yep... thats what it looks like we'll do. I dont see how its the board, but it never hurts to investigate. I'd be more tempted to blame the older hardware, that being the old hard drives, or oldish ram. We shall see.
I agree looks like a slow harddrive bus maybe, trial and error testing will find the fualty piece
sorry for bumping this topic but i've been trying all kinds of stuff...
talked to my friend Chris about it and he asked if the hdd light was on.. sure enough, the hdd light was blinking in sync to the system stutter. After lots of tedious crap installations of windows, i finally got one working, booted up on the secondary drive and music worked fine. Power down, go to Compusa, new seagate 250gig hdd.. install, drivers, still being retarded.
I took out one stick of ram, booted and tested and had the problem with both sticks. So, it isn't my ram.
might the heat from the video card right ontop of the north bridge like that mess with things?
I don't know shit about computers.. so.. i dont know if they'd even effect each other.
Here are some videos i recorded of music playing with the stutter. I thought though that if people weren't familiar with the songs, then they obviously wouldn't do much as the changes in the music might blend with the stutter.. but.. here they are anyway.
http://h1.ripway.com/Iamthecompany/Picture.avi
http://h1.ripway.com/Iamthecompany/Picture001.avi
if you'd like to familiarize yourself with the songs:
Taking back sunday - makedamnsure
Project 86 - Stein's Theme
in the second video (project 86) the same chords are being played as well as it skipping.. since for me on my computer, listening to it has the recorded skip, it skipping when it plays, and the chords.. it sounds like garbage.
any ideassss?
e/ those downloads probably won't last very long, so sorry if they don't work. ALso, in the second video, you can't see the hdd light.. not sure why, cause it is constantly doing what it is in the first video..
can you hook the os drive to the stutter free port and the secondary drive to the slow one,storage could tolerate a little stutter
so pata drives,have you tried a different cable,maybe you could checked in device manager to see if the ide conroller is set to use dma if available(although that should be defualt on a new install)
I have one of those Audigy SEs because the jack for onboard sound is messed up. The sound card blows, it will stutter when I play music, especially when I try to run a game with winamp playing. I play the MP3s over the network. When I play an audio CD (digitial since I don't have the audio cables hooked up) I don't have problems.
So anyway, I just have this thing for a temp fix until I order some better stuff but maybe the card is causing problems for you because it sucks balls. Oh and the audio on that thing sounds terrible.
There are pleanty of people who don't have problems with that sound card. Maybe your's sucks. It did it with the onboard anyways. It's not the sound card.
