AA and AF: What exactly do they do?
yogiB
I'm quite new to this whole graphics arena. I've just got an XFX 6600GT.
Can someone please explain what Antialiasing and Anisotropic Filtering actually do? It'd be good if some links can be given where I can read more about these technologies.
Thanks in advance.
Anti Aliasing basically adds a slight blur or roundness to all of the edges of the textures in a game to make the pixelated (sp) corners and edges look softer. And as far as the anisotropic filter goes it slightly changes the angle of parts of one texture (such as a floor or wall etc) using more irregular patterns instead of being perfectly lined up to make the images look more realistic as you would see them in real life. The AF is measured in texels by how high you set it (1x, 6x, etc.)
Anisotropic Filtering makes a HUGE difference in the visual quality of your games. Instead of any angled surface having a blurred texture the farther away it goes from you, and being sharp at the very start where it is flattest, it stays sharp the whole way out. There are example pictures in many new video card reviews demonstrating visually the differences.
Antialiasing blurs the colors of edges with eachother using a gradient to eliminate shimmering object edges and to make objects appear smooth-edged and rounder, like they do in real life. Without it, objects will look jagged and like torn paper on their edges.
AF = better textures due to them being sharper.
AA = better edges of objects due to them looking less jaggy.
WOW!
Thanks for all the info.
Which of these processes tax the system more? Or are they equally taxing?
Also, most reviews I've seen talk about 4x AA and 2x AF. Are those the optimum settings?
optimum settings are what is playable to you, and AA is more taxing than AF....8xAF is not really noticable imo from 16xAF, and there isnt really a performance hit anyways.
AA is far more demanding than Anisotrophic filtering. Anisotropic filtering is pretty much free on most of the new video cards, so I would really always put that at 8x or 16x.
Anti-aliasing, on the other hand, can slow down the framerate drastically, so that's more a per-game setting.
I have some AF comparisons laying around, so check them out below if you want.
wow those are nice comparison screens :) now can ya do one with 16xAF and 8x? hehe
