A8V rev2 probs. - need help from all experts here !
S&M X-SYS
Hello all , just got my rig together , installed xp and having some problems ....
Specs -
Asus A8V rev2 using bios 1007
A64 3200+ 0.09
2X512 OCZ 3700EB
X800XT PE
anyway - when I OC this rig - i am using auto for all memory settings -
Upto 220mhz fsb - the memory is working 1:1 and is doing 220mhz - but when i raise fsb over 220 - the memory drops to 200mhz ....
when i Use 1:1 (mobo saying ddr200 in bios next to this option) all I get is no boot ....
what's the problem here ? what am i missing ?
should i lower the HT speed ? use dif. bios ? any other option in bios for memory timings - coz there's an option saying 2:1 and DDR400 next to it ....
thank you all for all your help !
Should start off by lowering the HT to 4x once you're going past 220 as otherwise it'll be way too much over spec. Second, set the memory timings yourself and relax them 'till you find the optimal settings, auto may be pushing them too aggresively.
kewl thnx !
I am now able to do 235 at 1:1 ...
going to change atx case and get a better cooling on it !
