When I use the P-ATA connections on the motherboard with any of the 2 DVD drives and/or 2 DVD burners that I have, the drive will read then stop and read then stop and everything freezes when it stops reading even the mouse cant move when this happens. I have tried different cables and setting the drive as master, slave and cable select. Also, all drives are set to DMA mode 4.
This only happens with large file transfers from DVD or CD not from HD to HD. So far I have not noticed any pauses while burning discs, thankfully.
I found this issue when installing large games that come on multiple discs like Doom 3 and Age of Empires III. On my old system I could place each of the three discs in its own drive and start the install and it would move through each disc with out stopping. I found that on the A8R32 I get random pauses. It was not every drive or a particular disc. It kept happing on disc two of AgeIII so I put disc one into that drive and it happened on the first disc. I thought it had to do with that drive being on channel 2 of the P-ATA controller but after using just two drives on channel 1 it happened again.
Sometimes just after a pause the sound card would have continually generate popups stating that I had plugged in something new in one of the jacks. After the copy the sound card would be all messed up and Id have to reconfigure what was plugged into each jack.
I spoke to ASUS (as they to not reply to emails) and they just said to try a different Motherboard or different RAM. Oh, Ill just pull another one out of my Arent they supposed to test this kind of stuff for me?
Im sure it could just be my board but the issue seems much like the random spikes in the HD benchmarks and the pauses in many games before the 0311 BIOS came out.
I guess Ill have top RMA the board but my guess is that the new board will do the same thing.
System:
CPU AMD Athlon 64 FX 60 2.6G 939P - CPU FAN Zalman CNPS 9500 LED
MEM 1Gx2 Mushkin 184P D500 991493R
MB ASUS A8R32-MVP Deluxe XPES320 939
Video Card X1900XTX 512M H190XTX512DVN
HD 160G ST 7K 8M SATA2 ST3160812AS (4 Drives in 2 RAID Arrays)
PSU 2 (Yes 2 power supplies) Silverstone SST-ST60F 600W RT
DVD-ROM Pioneer DVD-106S
DVD-ROM Pioneer DVD-???
DVD-RW Sony DRU-800A
DVD-RW Sony DRU-820A
HELP!
and thanks for any help.
Richard
System:
HELP!
Richard
