A8N-SLI RAM question
Hi, I'm new here and it's time for my first of many questions. I'm going to be picking up an Asus A8N-SLI mobo soon and I'm having trouble deciding on what RAM to use. The mobo manual specifies:
"Memory - 4 x 184-pin DIMM Sockets support max. 4GB DDR400/DDR333/DDR266 ECC/ non-ECC un-buffered DDR SDRAM memory
- Dual Channel Memory Architecture"
and it has the following warnings:
"DIMM modules with 128mb memory chips or double sided X16 memory chips are not supported in this motherboard."
It then goes on to list some Corsair part numbers that do work. Basically I want to know if this memory would work.
http://www.newegg.com/app/viewProductDesc.asp?description=20-145-524&catalog=23&manufactory=BROWSE
I want to run 2 sets for a total of 2 gigs. Thanks for any help you can provide, this will be my first pc build and I'm sure I'll have many more questions.
Hmm, does it say that in the manual? I already have my ram and was going to install it in the board which should be here any day. I did not know about any crazy memory prerequisits. My four 512MB Dimms don't have four 128mb chips on them so hopefully that rules that out but they do have 16 chips each. What in the heck is X16 memory chips?
Anyways, I hope my fast expensive memory runs in this thing or I'm gonna be extremly pissed.
I don't know what x16 means either, here's what the instruction manual says:
"You may install 256 mb, 512 mb, and 1 gb unbuffered ECC or non-ECC DDR DIMMs into the DIMM sockets using the memory configurations in this section.
For Dual-channel configuration, the total size of memory module(s) installed per channel must be the same for better performance. (DIMM_A1+DIMM_A2=DIMM_B1+DIMM_B2)
When using one DDR DIMM module, install into DIMM_B1 slot only.
When using two DDR DIMM modules, install into DIMM_A1 and DIMM_B1 slots only.
Always install DIMMs with the same CAS latency. For optimum compatibility, it is recommended that you obtain memory modules from the same vendor. Refer to the DDR400 Qualified Vendors List on the next page for details.
Due to chipset resource allocation, the system may detect less than 4 gb of system memory when you installed four 1 gb DDR memory modules.
Due to CPU limitation, DIMM modules with 128 mb memory chips or double sided x16 memory chips are not supported in this motherboard."
and here's a shot of the QVL list:
