A8N-SLI Question
Q-Ball
I've been browsing through a few threads on the Asus SLI motherboard and seen the 24-pin ATX power connecter mentioned. I ordered the Antec Performance Plus case (w/ 430 watt PSU) from the Egg for my new system. While I'm confident that it has the juice to power my new setup, I'm worried about the ATX connector. With a 20-pin connector, does this mean that I have to buy a 20-to-24-pin converter to make the motherboard work?
the 20 pin works. but its really really not reccomended. you get random resets and the like. i hear it can even fry ur mobo, but dont quote me on that. i also hear adapters are the greatest thing to us, because that mobo is power hungry.
get a psu thats 24 pin by defult. antec neopower i hear is good, and its about ~100$ RMA ur psu, thats what i have to do.
sorry for spelling/grammer, its 2 am and im tierd..
430 watt is not good enough for SLI. well maybe for 2 6600. I get away with a 24pin psu with a 20 pin coverter but my psu is also a 550 watt with 35amp 12v.
Hey man, i wanna let you know that i have the PSU called X-Connect. Its the one that only uses the cables you need and its real shinny. Anyway, for almost 2 weeks i had the 20pin power cord that comes with the PSU and everything worked out great. I ordered the 20 to 24pin power cord( the cords can be taken out, changed, ect...) and put that in instead and i see no differences at all. Thought you might like to know that.
Well I'm not going SLI right away. It's just a 3000+ with one 6600GT. I was thinking of SLI as more of an upgrade option in a few months (like when I have more money :p). I have to go to Fry's today anyway, maybe I'll see if I can't get an adapter if they have one, but its nice to know I could probably get away without one if I had to.
You should be fine, I have a 'cheep' 20pin 350watt powersupply and mine runs. I can't overclock tho, as soon as I hit under 11.5v my machine reboots. Boot it up at stock speeds and watch the asus probe. For me, I run prime95 my 12v goes from 11.7 to 11.6, then add harddrive access on top of that, it went down to 11.58. Not sure what exactly mine goes down to when running 3d apps, but so far, only 3d apps have caused reboots for me, and only when overclocked.
Maybe I missed this, but what CPU and video card(s) are you running? I wouldn't suggest a 20 pin PSU for someone running 2 x 6800GT's or Ultras (or GTO's if they need seperate power plugs), expecially if running something like a strongly OCed 3500+ or even let's say a FX-55 at stock.
I was MOSTLY stable when I did some rewiring with a 20 pin PSU (as in made sure each video card had it's own power plugs, nothing else using them), but even then I went ahead and jumped to a 24 pin, now I'm 100 percent stable, no lockups on the Windows splash screen.
I'm going to be running a 3000+ with one 6600GT (for now). I downloaded the manual off of the ASUS website and according to it, even if I was running a 3400+ (sic) and 2 6600GTs, I should be ok with the 430 watt power supply. When I upgrade in the future, I will undoubtedly upgrade my PSU as well, but I think for now I should be ok.
**Side Note: I got the power figures from page 2-25 of the manual.
I'd say you'd be okay for now, and probably okay with two 6600GT's. For the record, if you go by the manual, with my 20 pin PSU I should have been stable, but again wasn't, best I could get was "mostly stable". So IMO 24 pin does help, even with a good PSU...I went from a 20 pin PC Power and Cooling to a 24 pin PC Power & Cooling unit with the same wattage and amps, yet gained stability just by going from a 20 pin to a 24 pin unit.
But I'd still try your PSU first, then go from there.
