A8N SLI DELUXE QUESTION
nealio
quick question...
can DDR2-SDRAM (PC4300) run on an A8N SLI Deluxe? I know it can run at 200 mhz as well as 266mhz, but I"m not too sure it will work.
Has anyone trield this?
DDR 2 will not work as the connectors are different.
You're looking for 184-pin DDR memory :D. Speeds range from PC2100 (DDR266) to PC4800 maybe (DDR550, 600...I don't know ;) ). Pretty much any 184-pin DDR memory will work with that board.
