A8N-E x2 3800+, wierd vcore problem
kawsy
I cannot seem to get a voltage between 1.4 and 1.5 even though my bios lets me select it. I'm thinking the voltage monitor works ok because the readings in the upper and lower ranges are accurate. Also, selecting 1.475, which is the first voltage that reads 1.5, is the first voltage where 2.5Ghz is at all stable. I've tried two different PSU's. One was a single rail 420 and the other a dual rail 550; no difference. I've also tried different bioses, clearing my cmos etc. The problem is the same whether I run at stock speed or OC.
So should I RMA the board or is my processor more likely to be the problem?
Vcore set to ... Vcore(bios monitor)
1.3 ................ 1.28 - 1.29
1.3125 ........... 1.29 - 1.31
1.325 ............. 1.31 - 1.32
1.3375 ........... 1.32 - 1.34
1.35 ............... 1.34 - 1.36
1.3625 ........... 1.36
1.375 ............. 1.37
1.3875 ........... 1.37 - 1.39
1.40 ............... 1.39
1.4125 ........... 1.39 - 1.4
1.425 ............. 1.39
1.4375 ........... 1.37 - 1.4
1.45 ............... 1.39
1.4625 ............ 1.39 - 1.4
1.475 ............. 1.48 - 1.5
1.4875 ............ 1.50 - 1.52
1.5 ................. 1.50 - 1.52
1.5125 ............ 1.52 - 1.53
The A8N-SLI had a similar VCore voltage bug with X2's. Try a newer Bios revision (when I was looking they had a beta bios that fixed the problem).
Wow thanks, that was it. Maybe now I can hit 2.5Ghz with < 1.5 volts! :D
I wish Asus would list the features of their beta BIOSes.
Go for it...that's about what I got with 1.5V from my X2 3800+ ;).
Now if I'd only known that Opteron 165s could be had for so cheap before I bought the x2. Looks like they go for about what I paid for my 3800. Oh well, this thing still kicks ass.
My 3800+ is running at 2.4Ghz @ 1.325v. I can almost hit 2.5ghz at 1.4v, but haven't tested it too much.
I actually sold my 3800+ and got the 165. At the time the 165's weren't hard to come by ;). This was about a month ago.
dont know if this is applicable but im running a 3200 venice @ 2.5mhz on an asus a8n-e at 1.375v.its rock solid and ive run every bench possible and never a crash or blue screen,its rock solid.
Were there any Vcore bugs with the Venice chips like with the X2's? I never ran a Venice with any of the Asus boards...only the X2 which gave me problems like the one described here.
