a7n8x deluxe bios
chuckm1020
i have a asus a7n8x deluxe rev 2.0. with 1006 bios. i heard there is a bios out there for this mobo that is exactly the same but has a setting for the memory to set it at 2.9V instead of the 2.8V, wich is the max i can go right now.
i found out, its the uber bios 1007, i downloaded it, anything i need to know before doing the flash? i heard u have to reinstall the sata drivers. is this true? i dont see how u could reinstall them since u do it in the windows installation.
HELP!!!! i cannot get this bios to flash. i coppied the 1007 uber bios to the floppy. the bios name is C18B10U7.bin, and is 256kb. i restarted and hit ALT+F2 to enter the flash utility. it says enter the disc, so i do that and hit enter, then it says to type in the filename, so i do that. then it says please wait for about 20 seconds. then a message comes up saying something like THE FILE SIZE DOES NOT MATCH!!!!. then at the bottom it says Y to program and N to exit. i hit Y. then it says something like programming, and shows a status bar, i let it sit there for 15 min and it went knowhere.
you may have better luck at the nforcers forum at http://www.nforcershq.com/
There is a ASUS forum there and there is always people talking about the A7N8X boards and the Uber Bios. Good Luck.
make sure your using the ones for the Delux verson. As the non-delux verson is a diffrent size.
you want the bios from here:
http://homepage.ntlworld.com/michael.mcclay/A7N8X-Deluxe/v2.0/1007Dv2.0-Uber.rar
You do not need to reinstall the SATA drivers with it, but upon bootup, windows may find new hardware, specifically the memory controllers. this is normal if it happens, as the bios renumerates the controllers. YOU NEED TO REBOOT AFTER THIS..
Also, you SHOULD NOT be using the ALT+F2 method to flash your bios.. it leaves parts of the old bios behind.. create a DOS boot disk, with awdflash.exe and the bios on it..(make sure to unzip it first) edit the autoexec.bat to say awdflash.exe XXXXXXXXX (where X is the name of the bios) /py /sn /cc /cd /cp /LD /E
the best thing to do, is to reset the cmos, and pop in the floppy you made.. You might need to go into the bios and select the proper FSB speed, but only do that.. save, and then let it boot from the floppy.. it will run awdflash, and flash your bios.. when it is done it will leave you at the command prompt.. at this point, I like to power down, and reset the cmos again..
This is the way I've been flashing my A7N8X deluxe since I got it over a year ago, and I've used every bios there was..
sweet, thanxs man, the awdflash.exe link doesnt seem to work right now, any other link?
edit: o yeah, would alt F2 still screw anything up? i know u said it left parts of the old bios, yesterday i used it to upgrade to the 1007 asus bios, and it seemed to turn out fine. but for the uber bios would it be bad?
yea that link seems to be finicky.. you can just go to asus's site, and go to the downloads section, and then under motherboards, a7n8x deluxe, and get awdflash.exe from there..
It's really little things that become noticeable if you use the alt+f2 method.. sometimes characteristics of old bios's are still there.. like not unlocking the barton's and tbred's.. or spread spectrum not disabling correctly..
the way I mentioned is really the best way to flash your board, as it makes sure that nothing is left behind...
