a
  • Thread starter Deleted member 104402
  • Start date
cause most manufacturers assume the majority of people will not be using a dual monitor setup? not to mention the technical problems associated with doing that
Backlight bleeding, LCD screens cracking instantly upon touch, edges breaking open and LCD crap leaking all over the place, those kinds of things.
A technology like OLED would be much better for something like that.
ChingChang said:
Cut off the borders yourself with a jigsaw :p
Pffft. That doesn't work. You have to use a table saw and then make sure that the screen is faced down. Then you guess ABOUT how far it is to cut off, and then run it through, and there you go! Borderless monitor! Doesn't work at all, but it's still borderless.
Count me in!
Now where can I find a table saw....
For only $4,599.00 you can get yourself one of these!
http://www.tools-plus.com/del36-790.html
Good idea, the table saw will ensure that the edges are cut straight and at a right angle to the adjacent edges. I'll have to try this sometime.
Anyone have any recommendations on what saw to use?
I would assume the sharpest, strongest, and thinnest ones for percision and smoothness of the finish.
Maybe some gold plated ones made by Monster that is THX certified.
You do not want to use the thinnest blade possible - it will have a tendency to lean away from the material towards the side that you are trimming off. The thinner the trim and the hotter the blade becomes (it can get quite hot depending on the material), the more pronounced the problem will be and your precision will actually suffer. Fortunately, you'd only be making eight cuts with the blade and will have the opportunity to let it cool a bit after each cut.
Keep in mind that I'm talking about high-speed mass production applications. Eight cuts may not be enough to cause a problem, but I'd still go with a blade of normal thickness. Either way, thinner blade body = more blade flex = less cutting precision.
If someone actually wants to try this, go through the yellow pages and find a local shop that specializes in custom plastics - they will either have the tools and blades on location to make the cuts for you, or they will be able to supply you with someone who can. Worst case, they'll point you in the right direction concerning type of blade. Another possibility might be a custom car or cycle shop. Worth a shot anyway
You could also remove the screens from the frames and build a custom enclosure for both screens.
I would use a 50 cent butter knife. Will get there eventually and save you the extra 5000 to buy a computer.
I pray to god you know he was kidding.
Pray to God, huh? Wow - I didn't think my response to a seriously-phrased statement would necessitate divine intervention. :)
Serious or not, the thinnest blade is not the way to go if you need to make a precise and straight cut.
lmao i can't believe you took his post seriously. that sucker born every minute cliche is so true.
great_gonzo said:
2 words.
Water Jet!
clickie
After it dries you are left with a precision cut and no possibility of deformation or plastic warping from blade heat.
That shit is amazing :)
Doesn't matter. Sarcasm is sometimes hard to detect on the internet so....
Even though it was said jokingly you could take the plastic off and cut away the right edge of one and the left edge of another and then put them together. You'd still have a slight boarder from the actual LCD frame (metal) but it'd think it'd be less than what you have now. It may look slightly tacky but maybe it'd be better.
You'd have to have a lot of money to think about doing something like that to a $300+ display though. :);)
