a
Status
Not open for further replies.
My understanding is that ATI's new Eyefinity gubbins is going to be supported on all of their 5xxx range, even the budget cards. We know for sure that a 5870 with 6 displayport connectors is due in a month or two. So perhaps in Q1, when ATI's low-end cards get released, we'll see a low-power-usage card with a similar feature of, say, 4 or 6 monitor support. I'm afraid that's only speculation though... but it would seem a bit silly (to me) for ATI to only offer the big expensive 5870 as a many-monitor graphics card when it's total overkill for non-gaming tasks.
I don't know of anything else available right now though, off the top of my head. Although didn't one of the ATI card-sellers once make a 4850x2 which could output to 4 screens? Again, probably not what you need since that's a massive card for a mini ITX system.
There are a few single-slot cards that support output to four monitors through funky 2xDVI<->Gigantor connectors. The problem is they all cost quite a bit as they are all sold as workstation cards.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814106040
Seems like a giant waste to me. I'd rather spend the money on two big monitors and the cheapest video card possible.
Right now I'm away from home, I use a 32" LCD HDTV for gaming and general home use.
I have a 4-screen (17"s) setup at home, and I need to hook up a system to leave there so I can take advantage of the idle bandwidth that my parents don't use. I figured I might as well be able to hook up to all 4 screens, just to be fuckin [H]. I have a Corsair VX450 sitting that I'll use, along with a Caviar Blue 640GB SATA drive.
Here's what I'm thinking.
Lian Li Q-07
ASUS Atom 330 Mini ITX board
JATON PCI 8400GS Quad-DVI
G.Skill 2GB DDR2-667
The only problems I can see are that maybe the video card is too long for the case, and the video card itself. I didn't know that the 8400GS could scale to 4 displays. Well it turns out it doesn't, there are two cores on the card. I'm not sure if the reviewer was just a retard or what, but this JATON corporation doesn't look legit. Anybody know any better solutions?
Also Lian Li Q-08 is coming out soon
Code:
http://www.hardforum.com/showthread.php?p=1034480601
Code:
http://www.youtube.com/watch?v=NFrIv9pgRr8
Read the comments
Zotac 9300ITX with a low-end, PCIe plug-in GeForce and an e3200, e5200, or e6300. (Or Zotac/Jetway 8200/8300 with X2 4850e or similar.)
That's true... couldn't you be using the onboard video as well, for a total of 4 ports?
You'd have atleast 1 HDMI to DVI but it should work... and be cheaper...
Yes, the onboard will stay on if you plug in a card using the same chipset (nV with nV, ATI with ATI). I'm not sure what's cheaper- an IONITX, a 9300ITX+Celeron, or an 8200+Sempron. If OP is considering an Atom rig anyway, he obviously doesn't need much CPU power, so it'll come down to which combination is cheapest. But any one of them will beat a quad-display PCI card. :)
Yea... the IONITX with a PCI-E x 16 slot isn't out yet... but will most likely be more expensive than the Zotac9300 w/ a cheap proc... might be pretty close though...
Sorry, shortcut FTL. IONITX was supposed to be IPX7A, the Pegatron board.
Edit:
Damn you, Blue Fox! :p
Status
