gemini8026
- Mar 12, 2003
The PSU is complete crap.......
Mine doesnt fire up half the time on cold boots (black screen and I have to reset because the mobo doesnt like the poor power spikes (and I run off a clean power line with a quality surge supressor,etc.
Whenever my CPU is in full force, the case fans SLOW DOWN, and it's not the mobo temp management.
I've had 3 occasions where I start doing something intensive and the computer totally craps out and reboots.
Sadly I cant RMA it, and replaced it with an old Antec unit I had.
If your gonna purchase the case, I dont recommend getting the windowed version, as the windows and rivets are CHEAP and scratch and break easilly.
I like the case, and the room inside. The weight and that are great, but the PSU and windowed versions are crap.
