I have an Antec True430.
Lately during startup at the point WinXP load screen appears one of the HDs starts going on and off, 6+ times, must be my C drive since it makes Windows take that much longer to load. At the same time the lights on the fans would flicker, as if the power was dropping causing the drive to go on and off.
I removed the side panel and found during bios loading just touching one of the power cords caused this. This cord went to one HD (I think C drive, with 4 total I forget), then to a fan controller and my 6800 card. I noticed on this cord one of the wires was out a little from the plastic end. I push it back in, start up with no trouble but the next day it started again and I can't find anything wrong. So the drive and fans would go on and off at windows load screen, but this time not even tugging on the wires would cause the problem like before with the loose wire.
I switched the HD to another cord but left the 6800 and fan controller alone . This time the system starts up quickly with no noise from the drive, but I did see the lights flicker again. I also notice when loading a large app, like Illustrator, from the C drive the lights would flicker. Note, 4 of the 5 fans are on the controller, but the 5th is connected to the mobo and it flickers too.
My 2005fpw 20inch LCD also just died, the backlight works but it won't show anything, not even it's own menu systems. Could this power problem effected the 6800 and damaged my 2005fpw through the DVI cable? The 15inch LCD on the vga port didn't suffer any problems. When the 20inch died I wasn't doing anthing intesive, just typing a message in a forum, no gaming or photoshop.
I don't think I left anything out, any ideas?
