I need a basic but gamable PC as cheap as possible because uni starts again soon and i can't wait till bulldozer out next year. When its out, i probably build another one base on it with 3x monitor!
Play games like GW, CS:CZ and maybe Starcraft 2 + web browsing
£400+tax+shipping
3) Where do you live?
UK
4) What exact parts do you need for that budget? CPU, RAM, case, etc. "Everything" is not a valid answer. Please list out all the parts you'll need.
PSU
Motherboard
CPU
Case
Ram
Reusing: ATI HD 4850 1Gb
6) Will you be overclocking?
Yes, a little bit
Already have Benq 24'' 1920x1200
Next week
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
None in particular
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? 32bit or 64bit?
I can get OEM Vista student version
Here is my prim build after reading this section everyday for so long (you start to get the drift!):
AMD Phenom II 955 BE - http://www.ebuyer.com/product/190673
650W-Corsair-CMPSU-650TX-SLi-XfireSingle - http://www.scan.co.uk/Products/650W...l-80plus-Efficient-120mm-Quiet-Fan-ATX12V-v22
Coolermaster-RC-331-Elite-Black - http://www.scan.co.uk/Products/Coolermaster-RC-331-Elite-Black-Silver-Midi-Tower-Case-w-o-PSU
4GB-(2x2GB)-Corsair-Dominator-DDR3-PC3-12800-(1600) - http://www.scan.co.uk/Products/4GB-...600)-Non-ECC-Unbuffered-CAS-9-9-9-24-DHX-165v
Asus-M4A87TD-EVO-AMD-870 - http://www.scan.co.uk/Products/Asus...-(x16)-DDR3-2000(OC)-SATA-6Gb-s-SATA-RAID-ATX
500-GB-Western-Digital-WD5000AAKS-Caviar-Blue - http://www.scan.co.uk/Products/-SATA-300-7200-rpm-16MB-Cache-89-ms
Total: £420.39 including delivery
Im not sure about the motherboard, saw it suggested on other thread on an AMD build.
I got a feeling that PSU might be a bit overkill and its not a modular one.
Lastlly, I suggest that there is a stick thread for Danni's master case list so he can link or maintain it from there!
Any things i should re-consider or change?
Cheers
p.s. If you suggest alternative part(s), i will look it up and do the price comparasion myself.
£400+tax+shipping
UK
PSU
Motherboard
CPU
Case
Ram
Yes, a little bit
Next week
None in particular
Cheers
