A question on using breakout cables
jordan12
So I just bought an M1015 card from a member on this board.
I want to use Sata drives with it, so I believe I need forward breakout cables.
I found a breakout cable that has the SAS connector on one end that goes to the card and 4 SATA connections on the other end.
Do I still provide power the standard way as I do the HDD's that are plugged into the SATA connections on the MB?
Make sure it is a forward breakout cable to SATA
SFF8087 forward breakout cable in the case of the M1015
monoprice usually has these cheap.
Yes.
Although I usually use hot swap cages.
