A fix to my problem installing programs
NightLinks
Hey Everyone,
I posted here before that i was having a problem installing quicktime and other programs. I thought it was NIS2007 but it wasn't. I read some where that windows vista for some reason is not registering regsrv32 and they posted a way to register regsrv32.
This is what fixed my program and i was able to install quicktime and winzip 11.1
Fix to problems installing programs.
Part 1
Go to Start then All Programs then Accessories right click on Command Prompt and Run As Administrator.
In command prompt change directories to go to c:\windows\
For people with windows vista 32bit they need to go to folder \system32\
For people with windows vista 64bit they need to go to folder \syswow64\
c:\windows\system32\
c:\windows\syswow64\
Once there type "regsvr32 vbscript.dll" without the " " quotes.
That will fix the problem.
plasma
So that vbscript dll somehow became unregistered, and that's probably what the windows installed needs to run:confused: Maybe norton does something with that script needed to install software in an attempt to protect you:confused:
