Hey all, I have a few questions on apeture settings. They're noobish but forgive me
I understand that the RESULT of adjusting your apeture in your pictures is in how the final exposure looks..an apeture of 2.8 will have what is in focus sharply in focus, and what is behind what is in focus blurred. An apeture of 8 will increase it quite a bit so what is behind what is in focus by say..oh.. x amount of meters..will ALSO be in focus. My questions really relate to ..erm..how this works, and how I can put it to use. At first glance it's pretty easy..I take a picture of a kitten (Thanks Schmave!
) and have my apeture set to 2.8 and whats behind the kitten will be blurred out..sometimes including the fur directly behind the focused part. If I want the whole kitten in focus, I would up my apeture to..say..5.6..I'm not sure of the number but a couple steps up, which would bring more into focus. I wouldn't go as high as say 8..because I don't want everything behind the cat in focus which takes attention away from the cat in the final picture.
Is that right? That's my understanding of it, and I know it's pretty layman's-ish. I can't grasp alot of the language they use in the explanations of apeture..I need real world examples and results, I never had a mind for numbers
Anyway, so thats the first part/question. The second part is this. How does apeture affect pictures taken at a distance? I notice that alot of zoom lenses are fixed apetures, say around 8..the cheaper ones mind you..and I was wondering if thats because apeture doesn't have as great an effect if you're zooming in one something. Also, how should you use apeture in cases where you're focusing on infinity. If you focus on infinity, isn't EVERYTHING in focus? For that matter, how does focusing on Infinity work? Ow, my head!
I do alot of night work..shutter speeds around 1-12 seconds, focused to infinity..and I often use the apeture to further control the amount of light I get in the final image. I've heard that shutter speed and apeture work off each other in long exposures. If you, say, adjust the shutter speed and then adjust the apeture at the same time, you could theoretically come up with basically the same picture. An example..a 2 second exposure with a apecture of 8, compared to a 1 second exposure with an apeture of 5.6. Do you follow me, those aren't exact numbers of course..just trying to get my understanding across. Somehow the apeture changes when used at night from being something that brings objects behind what is focused on into focus to being a tool to allow you to finetune the amount of light coming into the image. Again, is all that right? Help me understand please!
I know alot of you guys are deeply into photography, and really know what you're doing. If you get some time and don't mind sharing I'd really appreciate it.
Thanks all
croww
Thanks all
croww
