A decent motherboard!
dark_light
Hi guyz
I need a necent motherboard that have 2 pci express slots so that i could get 2 geforce cards to use their SLI techonolgy. It should be capable for handling intel core 2 duo processors. 4 GB DDR2. And a low price tag.
Please suggest some. any thing in asus.
Why dont you help yourself and go to asus web site and look at the sli capable core 2 duo motherboards, note the model number(s) of ones you like the features of and then check the prices at newegg or pricewatch. Then come and do a search of the forum on the one you picked out that is in your price range and read the posts about it. Then post a msg like, I am thinking of buying a xxxxx board and have seen yyyy problems reported what do you guys think?. If you are not carefull you might learn something, if nothing else than to depend on yourself in making decisions.
the problem with current SLI motherboards is that they don't overclock very well. At least not compared to the 975/965 motherboards.
I'm thinking Intel & Nvidia are going to play nice one day & release official drivers that work on the 975 motherboards. (I know they have hacked drivers to make it work)
Asus P5NSLI
One of only a few that fits the bill. Unless spending $220+ is your idea of cheap...
Sure, they don't overclock like 965/975 boards, but the op didn't ask for it to do so.
