I'm mounting a mobo on a sheet of acrylic and will be using standard mobo standoffs.
What is the best way to make the slits for the brackets of daughter cards in acrylic?
Am I just gonna have to drill holes in a line with a tiny drill bit? Do they make tiny tiny nano files?
I have though about just making the brackets hang off the end of the acrylic sheet but that
would take away from the clean look (and support?) I'm going after.
-Thank You
-Thank You
