theGryphon
- Nov 21, 2011
How about no IO plate? Just bare as it is... What are your thoughts on this people?
@iFreilicht, thanks for the comments!
As I said in my reply to SaperPL, the PCI brackets DO NOT stick out the side. They end right before the case ends. Some angled photos may be misleading...
Are you talking about the "Mini-ITX Maximum Component Height Restrictions"? If so, no, the 3.5" HDD does not intrude in to the 57mm height area, and it clears the 39mm height (it has 41mm clearance from the PCB).
If you needed a proto, it might be easier to mod a Lian-Li PC-Q02. When I built this, it was tight with normal pcie power plugs, but you can source low-rise (from alienware x51) plugs to make life easier
Will be interesting to watch this evolve!
