I have my 9800pro @ 420/720 stable in everything sept doom3 also. I get red and white snowThree D. Marks said:core: 421.2mhz
memory: 351mhz (702ddr)
This o/c works for everything cept DoomIII. I start to get white and red snow (NEVER saw red snow be4) after 5 minutes of playing DoomIII. I run that game at stock clocks.
t-readyroc said:Running mine at 420/350 stable in Doom3. I removed the shim & have an Iceberq on there. My next move will be to put on the Tweakmonster BGA RAM sinks, but I don't think I can stop playing the game long enough to let the Arctic Silver epoxy cure
With these speeds on Multibeast (link below), FRAPS never drops below 30fps (usually sits around 60fps) at 10 X 7 in high quality mode.
acascianelli said:r360 cores are better overclockers.
9800XT's run off of r360 cores.
9800Pro's come with both r350 and r360 cores.
only 9800Pro's with r360 cores are able to mod to 9800XT
acascianelli said:420mhz from an r350 core? you sure thats not a r360?
Trinz said:Just the thread i was looking for. I'm planning on getting a 9800 pro 256... question is, is there any way I can ensure a r360 core?
Also, would a VGA silencer running in silent mode be sufficient cooling for this OC? IF not, what's better. Keeping it affordable.
ubern00b15 said:
[Tripod]MajorPayne said:A 6800 GT or regular will knock the socks off of a Pro or XT. It doesn't matter which.
Andrew87 said:I only got a 1.5MHz overclock on the core(see sig). I still notice snow sometimes, and that's with a VGA Silencer and AS5. I think the lesson to be learnt for me is don't by stuff from Norweigen companies priced £200 too cheap around Xmas time
Rizen said:1.7v on the Pro.
