9800 pro or 5900
justin8018
im looking for a used card for like 100 bucks
i found a 5900xt OC for 90 bucks
whats the difference between the xt and the norm
i was just about to buy a 9800 flashed to xt for 110 and he just sold it
whast a better performer a 5900 xt or reg, or a 9800 pro
9800 , make sure its 256 Bit that means its the same thing as the 9800XT, all u have to do is flash it
9800xt is the fastest of the 3.. 9800pro with 256bit mem is next ..5900 comes in last in most things..
Where'd you see the 5900xt for $90? I'd get one for that price.
Doesn't the card also have to be like r360 core or something like that? Or does r360 apply to all 256bit 9800 pros?
justin8018 said:
how about a aiw 9700 pro?
Go for 9800. There is very noticeable improvement in performance when playing more intensive games.
If you want to use your computer for more than just gaming, and don't want to spend the cash on a TV tuner card, then the AIW is a nice card. If, however, you're primarily intending to play games on your computer, then stick with a 9800Pro, though make sure it's got the 256 memory interface on it.
R350 = original 9800Pro
R360 = 9800XT
Newer 9800Pros (256bit/256MB ones) were R360's also I believe.
I don't really consider the 128bit cards to be 9800Pros :). They are just a way to fool consumers into thinking they are getting a good card.
No it isn't, dumbass. the 5900 OC is much faster than that ATI crap. quit giving bad advice since you don't know shit about gr4phic5 c4rdz
Wow, chronicbluntz420... Good job immediately making yourself out to be a !!!!!!. ATI won the last round of video cards, thats kind of a given. NVidia stumbled. They pulled it back together this gen, and ATI screwed up with the paper launch problem. But no, 9800s are not "ATI crap". Lay off the weed and read a little bit.
-zac
Nvidia 5 Series SUCK .. 6 series dont ;)
In my unbiased opinion, I use whatever makes me happy. ATi, nVidia, whatever...
Last year I bought a BFG 5900 OC and wasent satisfied and returned it for a 9800 Pro, not knowing really anyting about either one. I was VERY pleased with the results and didn't get anything new until last week when I got my X800XT.
Just my 2 cents. :)
rofl! That one made me laugh haha.
LOL, me too. good to see he is b4nz0r3d!
As the others have said, ATI dominated the last gen of cards. Now it is pretty even. (nvidia has sli and ati has the x800xl)
I can be a dumb ass at times, it's a well known fact.. But, I've never managed to get my self banned.. :D Yet.... ;)
Sorry I just noticed this thread. On nvdia, XT means "worst of the class" while on ati, XT means "best of the class." 5900XT performs the worst of any 5900 class card. 9800 Pro outperforms the 5900XT. Just go to Toms Hardware and look at their VGA Charts Part IV. And it's like the other poster said, if you get a 256 bit 9800 pro, you should be able to flash it to a 9800XT.
