Excellent!ohlmsjm said:OS and necessary apps will sit on the 150g raptor...everything else is going on to my 500TB NAS.![]()
I certainly understand the confusion. I'm by no means an expert (yet - I have a BA2 on order), but there is a variant that does, indeed, only have 4 SATA ports. Look here:MrDisco said:What exactly is the optional discrete controllerIs that on the board or something extra I have to buy?
ohlmsjm said:I really want a board that is ROCK SOLID stable that performs well and I'm really not all that interested in overclocking to be honest.
I go with trusted names like "Asus", "Gigabyte", and "Intel"..as I've had good luck in the past with them. Therein lies the crux of my situation:
Asus Striker Extreme vs P5N32-E SLI vs Gigabyte DQ6/DS3 vs Bad Axe 2.
This is utimately the decision that I have been faced with and I know that from a technological limitation, only 2 of those boards will give me SLI for the future. I keep asking myself if I will even ever USE SLI or will it just be a waste of money for the board??
If I use SLI, go Extreme or P5N32-E
If I don't use SLI go Bad Axe or Gigabyte...
Is that how I should be approaching this??
ribs1 said:"No overclocking" "rock solid stable"
Go Intel man. Get the badaxe 2
ribs
fleggett said:I certainly understand the confusion. I'm by no means an expert (yet - I have a BA2 on order), but there is a variant that does, indeed, only have 4 SATA ports. Look here:
http://www.intel.com/design/motherbd/bx2/bx2_available.htm
The model on the right column looks like a slightly dumbed-down version, but it also falls within the BA2 family.
All the sites I've looked at only sell the full-featured version, like Newegg and ZZF. Just make sure you stay away from any model that has "LA" in front of its model number. Also, be aware that the BOX version comes with what looks like a 2-port USB bracket whereas the BLK variant does not.
Here's some more head-scratching. The initial reviews I read stated that the BA2 came with eSATA support, indicated by a red SATA connector amongst the cluster of blue. However, that appears now not to be the case, as the latest pics and reviews I've seen do not show a board with a red connector, just four blue ones. This is disappointing, but not a deal breaker for me. It might for you, though. Just thought I'd mention it.
Dudeyourlame said:Can someone link me this "bad axe" motherboard?
Jodiuh said:Just curious...why did you guys pick the Zalman's over the Tuniq?
Just curious, have you noticed a difference during real world testing between SATA 150 and SATA 300 controllers? Or is it like during RAID that the extra headroom comes into play?Dan_D said:The thing I hated about the first board though is the pathetic secondary SATA controller. It's only SATA 150 capable because it's using an older Silicon Image controller chip. The new board doesn't have this limitation.
This leaves me to wonder if there's a BA2 "out there" that no one has seen yet. I say this because, on Intel's download page for the BA2 manual, it clearly documents a red SATA connector that can be used with an eSATA bracket. Even the picture on Intel's webpage shows a board with the red port. However, all of the reviews and associated pics I've perused only show four blue connectors.Dan_D said:Intel used to only make a few motherboards, usually one or two based on a given chipset, now they have 4 or 5 versions of the same board in some instances.
deeznuts said:Just curious, have you noticed a difference during real world testing between SATA 150 and SATA 300 controllers? Or is it like during RAID that the extra headroom comes into play?
I don't do RAID so I've never even looked into it, but I just might since I'm going with a new build and HDD"s are so cheap, I might stripe some drives since my files will be on a file server.
chrisf6969 said:umm... The BadAxe boards are actually nice overclockers. Intel finally realized they were missing out on a good market and added nice overclocking features.
Look at the overclocking database (gotta find it), but many of the e6600, 6700 top results were with BadAxes!
ohlmsjm said:Someone suggested the Tuniq over the Zalman 9500 but I'm curious if it will fit in the setup that I've got listed on the previous page?
Also, what makes it better than the Zalman, just out of curiosity?
3far4shot said:i say get 680i because if u dont use SLI it will still give u good stable porformance on both sides
annaconda said:I got bought Crucial Ballistix PC6400 DDR2 memory EPP, which means SLI ready memory 2 X 1GB. Do you guys think i will get better performance with 680i Motherboard then 975X.
annaconda said:I have MSI 975X powerup Edition motherboard, and it gives me 7785 bandwidth @ 800mhz and 400fsb. and 7920 @ 430FSB.
annaconda said:What do you guys say should i buy 680i or keep the MSI 975X powerup edition. I want to do upto 500FSB with my E6300.
Orthosohlmsjm said:The rest of my equipment has arrived and I shall begin the week long festivities of putting it all together.
I don't suppose anyone has a rather updated list of common diagnostic utilities? (IE: Software that will help me ensure that I have everything setup properly)
Thanks again for all of the advice. You guys have been MUCH more responsive and helpful than other sites.
messerchmidt said:Asus boards have vdrop issues. I would avoid asus
I would get either:
1) evga i680
OR
2) gigabyte ds3 rev 2 or dq6 rev 2
the 975x does not apperal to me. costs almost as much as they i680 and is somewhat dated. The intel badaxe 2 with the pencil mod looks like a good 975x, but again it is not much cheaper than then the evga i680.
MrDisco said:hey guys thanks for clearing up that Sata + Bad Axe 2 confusion for me.
I suppose now i'm down to the P5W, the BX2, and the GA965DQ6. I think I read somewhere that the P5W uses 8 phase power, while the BX2 uses 5. True or not? Does this have any impact on stability? Also is there any advantage with the solid capicitors that Gigabyte touts?
I saw nothing like this, are you sure it's on good? BTW, how many screws did you mount the board w/?ohlmsjm said:...visually see the motherboard start to bow just from the sheer weight of the cooler.
Jodiuh said:I saw nothing like this, are you sure it's on good? BTW, how many screws did you mount the board w/?
Jodiuh said:I wonder if some boards are stronger than others...![]()
MrDisco said:Thank you for the info in this thread. It's been helpful for a newbie like me.
For better or worse I just bought the P5W. It was on sale and came out quite a bit cheaper than the BX2. I'm hoping it will be stable for my non-oc setup.
Can anyone recommend which 2x1GB RAM kit I should get?
Also is there any retailer who is selling the Tuniq Tower? Ncix/Directcanada haven't received any inventory for least 6 months now.
Just a touch over $200 AR on the egg now, right? I've had a set up to 900 w/ little trouble. Considering the next step up's closer to $300...yeah, best deal for RAM today IMO.MrDisco said:I was thinking of the Corsair TwinX 6400 C4 modules. Will that be good enough? Also will it allow for plug 'n play operation or will i have to tinker with the bios to get it to work?
