I know theres a huge difference, but i'm curious exactly what that would be. Would you say a 100% noticable difference or 200%? etc Are there any charts that compare these two?
Just trying to determine if the upgrade is worth the cost. Right now i'm running EQ2 with medium/high settings and it's pretty good, however I can't turn on shadows or it will lag too much.
Also with a P4 2.4 GHz 800FSB processor will I be able to take full advantage of the x800 XL?
Thanks!
Thanks!
