9600 GSO idles at 65C ?
piscian18
Hi I just finished putting together my new rig and I've run into a big issue. I have two 9600GSO's installed in SLI and at 30% fan speed with an open case they're idling at 70-75C. I wrapped most of my cabling to the bottom and yeah I know its messy but I haven't had time to play with it. If I crank the fans up to 80% with EVGA precision tool I can get them down to about 57/62C Idle respectively. This is with the 178.13 driver. Is it possible that the drivers might be the issue? Nothing else in the case is getting hot. CPU is cool to the touch rams warm. I did find one thing that was odd. The 9600GSO Dual slot in PCIex16 slot 1 is getting ridiculously hot, thats the one that I cant get cooler than 62-65C. Even when I shut the system down it stays ouch hot for a few minutes. The Single slot 9600GSO in PCiex16 slot 3 gets pretty warm but the second you shut the system off it cools down. Am I crazy? Are my cards bad?
2 cards will pretty much output 2x the heat so...
What are your temps with just 1 card?
I just got my card today, running 700/1750/2140 right now running atitool with fan at 80% and it hasn't gone over 62C, was getting around 71-72 with the fan at 50%. Even with 2 cards running that sounds kinda high for being idle.
bump added some details to my issue. Think I'm gonna just start a case with EVGA
Are you sure those temps aren't normal and safe? The 4850's idle at 70C - 80C...
I would agree but the ATi's run a bit hotter by default. I've been looking around a bit and it seems like these should at least be able to hit 50C with the fan at full blast but I cant even get that. I've got at least one person telling me theyve got the same setup but theyre idling at 50C with fan at 50% or less.
Found a definite issue with the 9600GSO Dual Slot. Pulling it off tonight to redo the thermal. Maybe I'm wasting everyones time but I found a lot of people complaining about this but no answers so if I get this fixed at least maybe somebody will find it and use it.
Definitely, let us know what you find with the dual slot card when you take it apart. I have the same card and it also runs hot unless I crank up the fan speed.
I PM'd you on this, but I'll post it here to offer up my numbers for reference. eVGA Precision has my idle temps at 51-52 and my highest temps at 57c. I'm using the Raidmax Smilodon Extreme, and its main identifying feature is the VGA cooling fan integrated into a horizontal bar that floats over the PCIe slots. It's only an 80mm fan, but it seems to be doing a helluva job keeping this setup cool. I set my GPU fan speed at 65% as well.
70-80C 4850s idle that hot? lol
The one I just sold with a GFX Chilla idles at 42C.
Well things have taken a turn for the meh. I'm thinking it's time to open a case with EVGA. After removing the Fan and replacing the GPU thermal paste with artic silver I'm not seeing any real change in the Temps. Though afterwards I put it under load and the cards jumped barely 5 degrees. Also what its worth I saw no temperature change on the core from 500-700Mhz. Thats over a 30% boost! 9600GSO is full of win. With what I have now Im gonna go ahead with benchmarks this week and a Brief 9600GSO review. Sorry about the school books. Stupid CCNA is eating up my life.
9600GSO DualSlot Fan removed
Single slot9600 defaultclock no external cooling
DualSlot SLi understress Post thermal paste replacement
I just did ALT+printscreen and pasted in mspaint. Then dumped it in photobucket. I'm lazy like that :)
Your temps don't seem too bad. On your sli screenshot there's only a 6C difference between your two cards under load.
For reference, I have an EVGA 8800GS single slot (pretty much the same card). My card idles at 60C with the fan at 55% (Note that the default 30% fan speed is way too low). This is in a matx case with 1x80mm intake, 2x60mm exhaust, 1x92mm cpu fan. At load, it goes to about 70C. It looks like the dual-slot cooler on your GSO is simple all aluminum with a pretty rough surface finish. I doubt it performs as good as it looks. Also, what is the max fan speed for your dual slot card? The fan on that card could be spinning at a lower rpm than the single slot even though both are at 56%. Also, the single-slot reference coolers have copper in the base (somehow I remember there being a heatpipe in the base as well):
http://www.techpowerup.com/reviews/EVGA/GeForce_8800_GS/4.html
I also only noticed a 1-2C change in temp after overclocking the core from 550mhz to 700mhz on my card. I would check with EVGA, but it doesn't seem too out of the ordinary to me.
The screenshots also show that bug in Precision wherein the 'TEST' button is available for single card setups, but grayed out for SLI. I read over eVGA's FAQ on the application and they don't have any fix for it yet.
Damn, I miss the simplicity of Coolbits, but at least eVGA is on the right track.
Might be a silly question but why not just run the GSO fans at there 100% settting and be done with it?
That temp seems fine. Increase the fan speed if you are really worried about it or get a 3rd party HSF...
I ordered an 8800GS and a Thermalright HR-03 GT and a Nexus 92mm fan. (I know, after the rebate for the video card, the heatsink and fan I ordered combined are going to be more expensive than the video card.) But anyway, I might look at the temperatures if I have the time and everything. (I ordered an Asus though.)
