939 solutions besides shuttle?
JohnleMVP
I'm interested in putting together a SFF PC like a shuttle for an AMD 939 cpu and some other extra spare parts I have.
My question is there any other barebones systems I should be looking at besides shuttle?
Also of the ST20G5 and the SN25p which is better and why?
My requirements:
939
DDR ram
PCI-e or AGP is fine
SATA or IDE hd is fine
PSU that can handle a 6600GT or 7800gtx
You can grab a microATX case and a microATX SFF case from various manufacturers if you wish.
Biostar iDEQ series are pretty nifty or a custom machine using silverstone sg01/ultra micro fly and doing it that way. I however having had a shuttle sn25p and the other (aspire x-qpack) and preferred the custom solution
I kind of want a cheap solution. The SN25p is about $200 and ST20G5 is less then $200.
We'll I just read HardOCP's review of the ST20G5 and they said it sucked. I'm focusing on the the SN95G5 now.
if agp/pci-e doesnt matter, the sn95g5 v3 is definitely the most solid of the cheaper shuttles.
You are getting a board, case, power supply and heatsink for $200. I would consider that pretty damn cheap! Now buying a new $500-600 Shuttle - that's a ripoff.
Go check out Biostar and AOpen's websites.
Yeah the shuttle is definately cheap and thats why I'm considering it. I pretty sure its what I will be going for.
Shuttle has some pretty good deals on re-certified S-939 barebones on their Ebay store:
ST20G5 $149
SN95G5 V3 $139
SN25P $199
SN26P $269
I have bought several re-certified Shuttle systems and they were always in excellent condition...
I would highly recommend any of the above models (except for the ST20G5) :p
Wow thanks for the link.
What do you think I should get v2 or v3? I don't understand why version 3 is more expensive when it is a NF3 250gb vs v2's NF3 Ultra chipset.
I'm planning on using a X2 3800.
My previous SN95G5 V3 worked great with an X2 3800+
I'm not up to date on the compadibility issues with dual core's and the V2 version...search on SFF tech shuttle forum to be sure.
The NF3 Ultra chipset is specifically for Socket 939. I know it supports X2 CPUs without a doubt. The 250GB was originally intended for socket 754, although I know Giga-byte later released a 939 version of the chipset (maybe only supports 800HTT instead of 1000HTT if I had to guess). Other than that the chipsets are pretty similar. When compared to the NF4, the firewall is different on the chipsets, the SATA controller is only 4 150MB slots, only 8 USBs I believe, and AGP as well obviously.
Well I think I'm just going to go with the SN21G5 from newegg. Its $232 shipped and has onboard video and I guess pci-e would be better for the future.
[H] used a bad BIOS or something - their review is far from the norm for this system.
Tech Report's review is much more balanced. Still not really "glowing", but a better look at it.
