92mm fan - hole spacing for mount?
IanM
Anyone know the correct dimensions for the screw hole spacing to mount a 92mm case fan? or have a technical drawing for this? I think it's 82.5mm but would like to confirm
I know this post is super old, but it came up in every google search I did so I figured I would post some useful information in it :)
I made some perfectly to scale templates in AutoCad (I know, I suck) and converted them to PDF so you can print them with Acrobat Reader to make perfect cut out templates! Make sure you turn off "Page Scaling" when you print them!!
"Fancy" holes: 120mm, 92mm and 80mm
"Fancy" holes: DUAL 120MM
"Fancy" holes: Single or Dual or Triple or Quad 140mm!!
"Simple" holes: 120mm, 92mm and 80mm
"Simple" holes: DUAL 120MM
Panasonic seems to have changed the location (or took down) their PDF's which show all the amazing diagrams for case fans (and their cut out templates):
80mm:
fba08a-1%2080mm%20case%20fan%20side%20panel%20cut%20out%20diagram%20dimensions%20cutout%20template.gif
90mm/92mm:
fba09a-1%2090mm%2092mm%20case%20fan%20side%20panel%20cut%20out%20diagram%20dimensions%20cutout%20template.gif
120mm:
fba12g-1%20120mm%20case%20fan%20side%20panel%20cut%20out%20diagram%20dimensions%20cutout%20template.gif
140mm (Sanyo):
140mm%20case%20fan%20side%20panel%20cut%20out%20diagram%20dimensions%20cutout%20template.gif
(also available HERE, HERE, HERE and HERE in case my webserver ever goes down).
I was designing a new side panel for my new i7 computer to keep it extra cool (four hard drives, 560 Ti and i7 2600 were cooking inside my super crappy case) and I came across this post. I was able to track down cached copies of Panasonic's spec PDF's and they were super useful in my design!
Here are a copy of the PDF's for 120mm, 92mm and 80mm from my web server :)
My design (sorry for the crappy autocad work, I'm not very good with the program):
All installed and works SWEEEEEEET! :)
LICK FOR HIGH RES!
New brushed stainless 18 gauge fan grill:
LICK FOR HIGH RES!
-Jamie M.
