WhyYouLoveMe
- May 24, 2005
WaXmAn said:I have the same issues with these drivers. After using my new quad sli in gamez I have the horrible desktop![]()
dtess17 said:could it be because quad SLI is NOT supported yet?
heatlesssun said:But its in the drivers!
aienstarborn said:Its in the drivers but Nvidia doesn't supported it as of yet. You are going to have problems with it more times then not. Sorry. I have the betas and will wait until Tweaks R Us gets their modified drivers out.
heatlesssun said:Not necessarily. With the new set of drivers on nVidia's site, I am actually having no problems that I've noticed so far. Even got Prey working in QUAD-SLI.
Not a lot of games seem to be taking advantage of QUAD-SLI. F.E.A.R., Quake 4, and HL2 E1 seem to be using it, looking at the SLI indicators. However, all the games I have at least tested seem to be running stably.
QUAD-SLI its self my not function in a lot of cases, but it looks like the setup is stable and allows for enjoyable gaming.
aienstarborn said:Thats cool, but what I really should of said is that there is not a whole lot of support for it as far as games go, and there are people upset because they have problems with it and there comps when they leave games. It will get better as Nvidia realizes that people are really using it.
heatlesssun said:You're right, there's not a lot of games that are using QUAD SLI, but my point is that it seems to be stable.
I too had a lot of these issues, the desktop going hippy colors and a few crahses and this last set of drivers is NOT showing these problems. QUAD-SLI is not going to wreck your system.
I don't know why nVidia is being so cautious about QUAD-SLI. They have certainly had less stable supported stuff of there before.
B. W. said:Does hiding the tray icon not work for anyone else? It keeps coming back..
Same here. In the new Control Panel, you are supposed to be able to disable the tray icon under View --> Show Notification Tray Icon, but all this does is "hide" it like other inactive tray icons. It's still there. After switching to Nvidia's "classic" panel, under "Tools" you can clear the checkbox: "Enable Taskbar Icon" -- however this setting does not seem to stick with this driver release. One workaround is to disable the "NvCplDaemon," "NvMediaCenter," and "Nwiz" startup files. (Remember to disable the "NVIDIA Display Driver Service" if you do this, or it will keep restarting the same files.)Vulcanworlds said:yes it doesnt hide for me either (comes back at startup) and hide you mean disable in the properties thing right?
After I installed the new drivers, I noticed that my machine felt a little slower, but I haven't tried any games yet (and I used Driver Cleaner from the instructions in the sticky).
Same problem here.. its annoying having it come up at boot upAnyone know why a notice pops up saying "SLI Rendering Has Been Disabled" when Im not even using/running SLI to begin with? It was doing this shit with the same drivers released on the 2nd week of this month.
Eva_Unit_0 said:I've used the beta version of these on my lowly little 6200TC (backup card to my x1800xt) and they seemed to work well. But it's only a 6200 so it's not like any new features are being stressed with this particular card. I absolutely hate the new control panel, though.
poee said:One workaround is to disable the "NvCplDaemon," "NvMediaCenter," and "Nwiz" startup files. (Remember to disable the "NVIDIA Display Driver Service" if you do this, or it will keep restarting the same files.)
poee said:Same here. In the new Control Panel, you are supposed to be able to disable the tray icon under View --> Show Notification Tray Icon, but all this does is "hide" it like other inactive tray icons. It's still there. After switching to Nvidia's "classic" panel, under "Tools" you can clear the checkbox: "Enable Taskbar Icon" -- however this setting does not seem to stick with this driver release. One workaround is to disable the "NvCplDaemon," "NvMediaCenter," and "Nwiz" startup files. (Remember to disable the "NVIDIA Display Driver Service" if you do this, or it will keep restarting the same files.)
[/size]
