Funky_Junk
- Oct 1, 2005
Im looking for a 90mm fan to replace the stock one on my Thermaltake Tsunami case. Heres the specs for the current fan:
Max. Air Flow 56CFM
Fan Dimension 90x90x25 mm
Noise 35dBa
Rated Voltage 12V
Bearing Type 2 Ball Bearing
Started Voltage 7V
Connector 3 Pin
FAN Speed 285010% RPM
First off, I would like the fan to support rpm monitoring. At full speed its alright for the fan to be 35dba loud but it has to move at least 50cfm of air. At the low setting I would like it to be under 25dba. These are just recomendations but if theres a better one let me know.
Max. Air Flow 56CFM
Noise 35dBa
Rated Voltage 12V
Started Voltage 7V
Connector 3 Pin
