- Jul 24, 2008
Don't you hate when that happens?!?picked up a 16gb last week and im pretty happy with it, still not happy with price but what can you do, at least i got it for msrp.
got the powercolor reaper version for the size, to clear all my water cooling. then after getting it installed i decided to install a mobo i had been sitting on, got a massive leak in my cpu block and ended up ripping it all apart and going back to air. wish it would have happened before i got the card, i would have gotten a 3 fan model.
this little thing ocs great but there isnt enough cooler. with +200 core, -50mv, +100 mem, its pushing to and holding 3400+ BUT it gets toasty, with the hot spot and mem pushing 90s and the core is sitting at 70ish.
keeping the oc within "comfortable" temps its fine and the system is now probably quieter than my custom 360 loop(cpu and gpu)...
I'm sitting on a 7800x3d and a MSI Pro B850M-A mobo that I don't feel like installing because of my 360mm is stretched to the limit, plus I don't feel like converting it to AMD.
I wish I had 16GB of VRAM, hope your new precious brings you plenty of joy.
