vertigomhs
- Aug 1, 2008
A friend of mine is getting a gaming pc from his wife so this is his Xmas present and I'm helping her to get things together along with your help of course
EDIT: 900 dollars not 700!
- Gaming, web browsing, etc. Going to be his main rig.
- Around $900 give or take, excluding tax and shipping but preferably included. There is some wiggle room.
- US, Los Angeles and San Diego. There is a MicroCenter (and Frys) we can pick up parts from if needed.
- Basically everything, CPU, RAM, Motherboard, GPU, PSU, Case, DVD drive, HDD and SSD?
- None.
6) Will you be overclocking?
- No, so no aftermarket HSF is needed for now.
- Going to be 1080p.
- ASAP! For Xmas if possible
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
- None specifically are really needed.
- Have this covered!
- None.
