So, I did try to resolve this without help, but you'll see why this one is a [H]ard one to simply Google.
I'll try to make this short & sweet, but also informative enough to minimize unnecessary back & forth ...
Old(er) Desktop:
This drive is actually going to a mirror in a home Unix server with somewhat more modern parts, but that system so full I'd have to break an existing mirror prematurely just to test this 8TB in that box (and if "the new guy" here doesn't work completely inside, that mirror is at more risk). So I'd much rather test it in (around, attached to) this older desktop first.
However:
Q1: Where do I begin to troubleshoot this? i.e., What could it be?
Q2: Did I already reveal something that prevents a (or this) 8TB NAS drive from working and I don't realize it (b/c I'm not all *that* experienced at this)?
Q3: How would one go from here to find out if the drive is really dead or if it can be brought up if only you had ____?
Q4: What would you do in this situation (besides upgrade all your [H]ardware)?
I considered BIOS: but Gigabyte hasn't updated anything relevant for this board since mid-2011 (but it does have a ACHI mode I'm now running in, and potentially a new ACHI driver).
I considered HDD firmware, but that seems to be up-to-date on-delivery (these 8TBs had a noise problem before that FW).
I considered that this drive just may not work at SATA2 or that this desktop mobo was never designed to address 8TB. (This is where we get out of my current depth.)
I considered calling the 8Tb "DOA," but it does power up, spin, and make a little noise which seemed to change/reduce when the successful testing started on the "phantom drive."
I'm considering that I might try to replace this via Newegg, if only for the poor packing, but I'd rather confirm the actual condition of the drive. And I don't want to have Seagate come back and say "it works for us" b/c I have some [H]W, FW, or driver deficiency.
I'd greatly appreciate any help to push me in the right direction to resolve my conundrum. Thanks!
Old(er) Desktop:
- CPU: Intel Core i5-750 2.66Ghz
- RAM: 12GB
- PS: Corsair Enthusiast 650W 80+ Bronze ATX
- mobo: Gigabyte GA-P55A-UD4P LGA1156
- 8x SATA2 3Gb/s headers (6x by P55; 2x by Gigabyte)
- is anything else important?
However:
- This 8TB HDD came very poorly shipped (Newegg "Business"): absolutely nothing between the anti-static bag and the barely-together cardboard box on the bottom and sides (just some bubble wrap on top), inches to slide side-to-side, the HDD green board on the bottom, and the box bottom design depresses easily, opening holes where only packing tape stood between the anti-static bag and the elements of shippers and a Mid-Atlantic winter.
- I've only got some USB3 enclosures from some old 3TB drives -- trying the 8TB in one of those enclosures in both Older Desktop and the final destination via USB3 only yielded some rhythmic whining/buzzing sounds from the drive (so it's getting power) but no recognition from FreeBSD 10 or Windows 7 Enterprise (even nothing new under Disk Management so, no, this is not a typical "oh, just partition & format it" answer).
- Installed it into Older Desktop connected with a SATA2 P55 header and got the same rhythmic buzzing/whining at first (it does go away)
- I was just going to DOA RMA this and then I tried Seatools for Windows (1.2.0.10) b/c I'm pretty sure that's the first thing Seagate would try or have me do:
- This tool finds my 2x SSDs and my 2x WDC HDDs
- But it also finds something else: a completely unnamed and unidentified, under a USB--1394 header, even though there's nothing on that type of connector
- In fact, there's nothing else connected except an APC Battery Backup, an internal 3-port USB3 card, 3 optical drives and an internal photo-stick-media type of device (SD, MMC, etc.)
- Seatools literally only gives me "-------" as the SN, a pic like for the WDC drives (an open HDD), and Drive Status = "Ready"to Test"
- All Basic Tests come out positive for this phantom drive, which might/should(?) be the 8TB
- However, this drive just won't show up in Disk Management to allow progress
