thespymaster
- Jun 17, 2002
Does anyone know if it'll fit, I'm sure looking at getting one...
AMD RULES said:probabley...but how are you gonna fit a psu in it that is powerful enough for the card and a decent system ?![]()
sleepeeg3 said:Actually, I take that back. Brainfart thinking the X-Qpack was the same size! I answered this before and I don't think it will fit:
http://www.hardforum.com/showthread.php?t=1109049&highlight=microfly
However, I think I based that assumption on the PCI-E connector coming out the end, so it might.
sleepeeg3 said:Someone posted earlier the GTX was 9". I don't think you have 3-4" in the X-Qpack, because I only have 3 1/2, not including the PCI-E connector and I think the JPac/Microfly cases are 1 1/2 longer. I'll try to measure when I get home to give you a final guestimation.
My system is an awesome room heater!![]()
sleepeeg3 said:X1900XTX = ~9"
8800GTX = ~11"
Jpac Length = 15"
Jpac interior = 13"
X-Qpack Length = 14"
X-Qpack interior = 12"???
Jpac interior - 8800GTX = 2" to spare
So you will be fine.![]()
bump --- I wouldn't mind knowing the answer to this eitherMrE said:I figured that I'd ask here instead of starting a new thread asking roughly the same question, but instead of a Q-Pack, if the GTX will fit the Silverstone SUGO case?
I ask due to the orientation of the drives in the SUGO mount across the front. Since I know the card is roughly 11" I'm going to have to break out a ruler tonight to see if I can fit it.
-E
[RCKY] Thor said:Well, I got my 8800GTX crammed into my microfly!
The power connectors do touch the drive bay, but I managed to slide it in. Next time I have the whole thing apart, I will probably mod the 5.25 cage
shawnol said:Ultra + DFI = EW
550W + 8800GTX + DFI + ULTRA = not good idea i think personally.
dworley said:I have a Micro Fly and tried fitting the 8800GTX also - the PCI-E connectors interfere with the drive cage.
I could make it fit by pressing the top edge of the plastic power connectors just under the lower edge of the drive cage - it's very tight and forces the end of the 8800GTX board down and to the side slightly.
I plan to mod the drive cage by cutting out a small section so as to leave room for the power connectors with no pressure on the board.
