8800GTS 74C Idle!
you can get Vista to look just like classic XP, when I loaded up the basic scheme windows loaded up quick etc like XP and heck the only way at times to tell I was in vista was to browse folders or look at the start manager and read Vista on the side.
Also, I'm in XP right now just to make sure how much of a temp diff there is...
my GTX is idling at 68C! and possibly going lower still...
in Vista it was idling at 78C...
vista + aero makes a HUGE difference...
My temperature for my 8800 GTX has been really high too. It depends /alot/ on the temperature of my room. (at least for my computer specs in sig)
When my cpu is around 40c+ my 8800 will be around 75-80c+.
Right now my cpu is at 36c so my 8800 is around 70c.
Yesterday my cpu was at a nice 30c and my 8800 was at a 65c.
These are all at the 60% fan speed for the 8800. Putting at 100% reduced the card temperature by about 8c.
I really don't think a high 70-80c temp at idle will damage the card as I never bothered reducing the temp in the past 5 months I have had it.
When in use playing Bioshock (hot day 8800 idling at 78c) the max temp was 84c with the fan at 100%.
*rambling* So I think the high temperatures are tolerable for the 8800 and it is possible to get a hot card idling at 80c down to a cool 57c as I did.
Core temp @ 58c Idle (just folding / internet browsing atm), clocked @ 621/1458/900 (1800), fan is at 80%.
Card Ambient temp reading says 47c
Processor is @ 100% (SMP Folding): 46/ 47c (TAT) clocked @ 3ghz atm.
im also having similar problems as the OP... my 8800gts 320mb is OC'ed to 612/918, and it idles at 70C, and goes up to 91-92 when i play MOH airborne... Is that bad?... Its weird because the card use to have the exact same OC and idles around 61, after i updated the beta drivers the temps sky rocketed. Could this be a problem with the beta drivers?
How are you OCing? RivaTuner or something? If via a BIOS flash you shouldn't see a change, but the latest betas (163.67) "break" OCing via software as they unlink core (ROP) speed from shader speed. Future version of RivaTuner will allow you to OC shader and core separately, so this is actually a /good/ thing, just a temporary annoyance.
Same idea as RivaTuner. And yeah, that's likely the cause of the change in temps. If you go back to 163.44 they go back to normal, right?
my card is idling right around the same as yours, as soon as i put fan to 100% it dropped to 64% and counting. I have done cable management, but I still feel this computer runs pretty warm. I need to get a fan controller for my new build, maybe I'll go look this weekend. Mike
btw - At 100%, this fan is still insanely quieter than my ati x1800xt, I love it.
just reinstalled older drivers (the one on nvidia site), the card is STILL overheating =[, and the thing is, even at stock speeds its still the same temp :confused:
i hope i didn't screw up my card by overclocking it...
hey, just built another pc, and now at idle its like 20 degrees cooler, def must of been case and airflow. Mike
i have evga 8800 640mb about a week ago and it's idling at 60c and 80-85 on load. then i resit and applied artic silver and still idling 62c but under load its only 70-75c. i suggest like everyone to resit the fan.
