SoSilencer
- Nov 3, 2007
Like everyone else I'm building a new comp with an 8800GT and need PSU advice. I thought I had it figured out but after reading the forums a bit I've gone and confused myself. I actually have a specific question though... nVidia seems to recommend 400w with 22a 12v for a single 8800GT or 450w with 24a 12v for SLI. Does this get split between the PCIE slot and the extra power connector or does all the power have to be on the same rail? How much power per rail is really needed to run an 8800GT?
Since I have the original FSP Blue Storm AX-500A I was looking at the FSP Blue Storm II (http://www.newegg.com/Product/Product.aspx?Item=N82E16817104034) but it has two 18a rails which seem like they don't meet the above requirements. The Corsair 450VX (http://www.newegg.com/Product/Product.aspx?Item=N82E16817139003) seems to be really popular here and has a single 33a rail so that seems like it would be a safer choice but maybe there are better options? Specs for the machine will be Q6600, 4gb ram, 8800GT (probably overclocked EVGA 700/2000mhz), 2+ HD and 2x dvd.
Also I noticed that some motherboards have an 8 pin cpu power connector and this is not something I'm familiar with. The Corsair 450VX seems to have a cable for this but many PSU don't. If that Corsair unit isn't adequate for this machine, what spec/rating/title should I search for with a PSU to know that it has all the right cables?
