Its a tough call. The 7950GT is fast. I guess it depends when you are willing to replace it. If you go through video cards pretty fast you might want to wait for a 8800 refresh but if you are going to hang on to whatever you are going to get for a while I would go for the 8800.
Right now I have a 7950GT and I am going to hang onto it for a bit to see what DX10 is going to do.
Anyone here that says to go for a 7 series is smokin crack. Why would you NOT go with an 8 series if you could afford it? The IQ is godly compared to the 7's witch didn't look much better than the 6's.
The performance difference is huge, but if you're gaming at 1280x1024, there's no point to getting the power of the 8 series. You're better off with a sub $200 card, then buying whatever the latest sub $200 card is in two years when you finally start feeling a performance crunch. Higher resolutions let you see the difference today.
I just put a system together and took the (expensive) plunge with the 8800GTX. Why? Well after reading the performance reviews I was left with the impression that this series (8800) is an entire new generation and seems to produce gaming frame rates TWICE those of the not so old 7900 series - that's some jump!
It will also be DX10 compatible which will be important in the near future. I can't wait to see the likes of Conan and Crysis when they get released.
At present my 8800GTX is bored with that puny task of full res all features Battlefield 2! - No challenge at all.
My advice:
If you have to get a card now - go 8800 if you can afford it/if 3D gaming is priority. If you are short on cash then go 7900.
Sure the price will come down, but then what will you be drooling over? I'd say the 8800 will be the top for a while with some "extreme " editions and "extreme" prices (although you can overclock this easily with supplied software)
Good luck!
Ollie![]()
I'm also betting that there will be a card with 8800GTS/X performance in the next generation that is smaller and less power-hungry. And cheaper.
Today I purchased http://www.newegg.com/Product/Product.asp?item=N82E16814130071
$359.99 after $30 mir
For only about $100 more than the 7950gt you get higher performance and future dx10.
http://www.chiefvalue.com/product-_-productdetails.cv_-_item--14-130-080
Me too, I went and ordered mine today.
And it was only $9 more than at newegg for the super clocked version here with the same rebate.
"very nice"
I saw that deal on newegg. What do you think the odds are the price drops on that this month later while the rebate is still up?
Its a steal as it is, but my main concern was maximizing the eVGA step up by buying it later this month, and maybe catching another price drop.
Thoughts?
Stepping up same in the same generation is rarely worth it unless its from a really low point to a high point. Because they charge full MSRP, where as you can prolly sell your card on ebay, and buy from a e-tailer and get it cheaper then a step up.
They key is when the next gen of things come out. Because then the value of your current card drops dramatically in resale, but you can still get full value from eVGA on your step up.
now correct me if I'm wrong but, I think whats getting left out is that a DX10 card + Dx10 game -DX10 O/S = DX9 performance. the fact that m$ tied directx 10 to vista means to see the real advantage of a DX10 card, your going to have to pony for vista if you don't already have it. Am I missing something? I was on the same upgrade path and ultimately decided on the 7950gt myself, since i hadn't intended on buying vista for another year. can anyone clarify?
Having DX10 does not affect DX9-game performance in any way. It's a psychotic performer under DX9 platforms as well (such as XP), and DX9 applications/games on Vista.
Hey I just ordered a Westing house LVM-37w3 last week to play my 360 on and use as a computer monitor in my office. I haven't been into pc games but am really thinking about taking the plunge. So all of my decisions are based off of my 360s power. On new PC plan on playing games, surfing the net and using photoshop a lot. Heres what I got lined up.
RAIDMAX smilodon case with 500w ps
GIGABYTE AM2 SLI Mobo
EVGA 7950gt
AMD Athlon x2 5200+
512mb x4 533 ddr2 ram
seagate 320gb hdd
Now my problem is that I want to pick up FEAR and Company of hero's and run them near max at 1920 x 1080. Will I be able to get good results from the 7900gt or should I bust the budgett of $1000 for the 8800gts. Oh yea won't be running vista for atleast 6 months.
Well if I had to shave some things off of my rig what should I cut down on? Maybe athlon x2 4800 opposed to 5200? or take ram from 2gb to 1 (don't really want to do that though).
Bad idea on the 2GB ram to -----> 1gb, so yeah, if that has to be done, don't do it. The CPU change would be worth it if it would enable the video card upgrade, however. I don't know if you overclock or not, but if so, the new Brisbane X2 3600+'s are supposed to be stellar. That would shave some more off.
I have a 1gb in my laptop and photoshop abuses it something fierce so like I said refuse to do that. I have decided to go with the 8800gts. I took the 320gb hdd out and added a 80gb hdd. I already have another 80gb hdd. so i would be cool for a month or two till I can add a bigger one. I haven't ever overclocked anything but really want to step my game up. I know how to build them but never built a new one from the ground up. Got the price down to $1040 over all with the dvd drive and some other little things i need (dvi cabel). totally amped to build it hopefully everything goes to plan this month and I can build it at the end of the month.
Nice, and that is a good move. I almost suggested trimming the hard drive some, but thought the other might be a more effective suggestion at first. Congratulations, and best of luck with the build! If you run into any problems while building, of course post on the forums, and PM me if you want me to look too
. Just remember to take it slow, but not so slow you second-guess yourself
Thanks I really appreciate it. My thoughts are the HDD get so cheap so quick that I know I can pick up another one later with out the wife batting an eye. But to but a $260 video card and then turn around and ask for a $390 she will be like what hell are you talking about. She has been really patient this month with me dropping $1075 on my monitor and then asking to spend another grand on a new pc. I did score some points when I showed her this site with the same case and some components that they were selling totally built for $1900 opposed to my poultry grand! LOL! I didn't list an OS because I can score xp pro 64 for $15 through my school. any suggestions on whether to go 64 or stay 32? Man I hope this month goes right, it would be the best month of my life (next to getting married!)
