8800 GTS 640MB OCers?
soulesschild
Any users with an 8800 GTS 640MB (STOCK) OCed? I'm just curious on what people are clocking theirs at and how stable/hot it is. Is the performance gain really that much?
Flashed to 648 / 2Ghz mem and 1512Mhz shader clock. Yes, it's worth it. The overclock puts me about the same speed as a stock GTX. I have adequate airflow through the case and my temps are 54 idle and 72 - 74 load. Again, load temps depend on your case cooling though.
Your temps are lower than people with stock speeds. You must have some serious cooling!
How did you overclock your shader clock? Is it also possible in Vista x64? Any significant rise in heat?
I have the 576/850MHz eVGA 8800 GTS 320mb superclocked card... had a few lockups playing with higher settings.. my case has very good cooling... what are other people getting for OC's?
I'm sitting stable at 620/920
Rip the bios to a file with nibitor and you adjust memory, core and shader. You can find out your shader clock in Riva tuner. Also, there are steps so 650 Mhz on the core in ntune or ATI tool isn't really 650, it's 648. This explains the steps pretty well...(http://www.thetechrepository.com/showthread.php?t=133).
Once you adjust the bios using nibitor you use nvflash and flash the card. This will affect the core, memory and shader speeds. Once you are flashed you never have to worry about software overclocking again though ;)
Had to add 2 Yate loons pushing air through the case to improve mobo temps, I had this setup before I even had the 8800 GTS so I'm not sure what temps would be without it. I affectionately call it the "wall of air". Zip tied 2 x yate loons then double side taped them at an angle so that they cool the NB, Memory, GPU, SB, Mosfets. Works really well to avoid hot spots and keep airflow moving through the case. Memory even at 515 Mhz @ 2.3v isnt even warm.
you don't overclock the shader speed. it changes automatically relative to the gpu set clockspeed.
as for the different gpu thresholds:
Max I got "stable" was 615/2000 or maybe 615/2100, I forgot. "Stable" being I completed a run in 3dmark06 without crashing or artifacts.
I think a 3dmark loop for an hour or two is the best choice, keep a close eye on temps and make sure your case has good airflow!
my gtx clocked up to 660 / 2100, completed a 3dmark06 run with no issues at a score of 12344
however I am not too confident in that since i havent run a 3dmark loop yet
I have an Asus 8800 GTS and i get it very stable up to 594/1944. It SEEMED stable at 621/1944 and i ran the 3dmark06 game tests 99 times each (~9 hours total) and it had no problems doing that BUT when I leaved atitool artifact scanning on, after about half an hour it did start getting artifacts, so I lowered the core to 594 and all is fine now.
I did have another 8800 GTS too (club3d) and it had no problems with 648 core but the memory could only do 1782 (also tested with atitool artifact scanning). So I kept the Asus as I want as much memory bandwidth as possible.
Edit. So don't just rely on 3dmark loops. The club3d did the 9 hours of 3dmark06 without problems at 1998MHz memory! So before saying your clocks are fine, run atitool srtifact scanning for an hour. If it doesn't report errors during that time, then it most likely is truly stable.
675/2100 here. About 11k 3d06 marks.
Load temps of around 46 on water.
Stable in 3Dmark, oblivion and 8hrs of ATI tool.
Ooops! Good catch. Looking from my notes, that was the one that didn't run.
654/2158 was the stable speed.
http://home.comcast.net/~mpersons/10837_allsettings.jpg
Temps were too high (air cooling here) at ~78C, so I run 620/2006 daily.
*edit image too big*
-mike
First of all 78c isn't too much for the g80 at all! I would only start getting worried if temps should go over 90c. And I would very much like to see atitool artifact scan screenshot running for 10 minutes on that 2158 speed. If it actually doesn't report errors for 10 minutes, then that really is a very nie oc.
I'm not sure what I'm doing wrong with ATI Tool, but no matter the clocks (even WAY underclocked), ATI Tool artifact test hardlocks my system after exactly 5 minutes and 13 seconds. It has never found an artifact, however.
UPDATE: It does the same with with my roommate's older 7900 GT. Same issue upon reinstall. Probably a windows problem.
Oh well. It 3DMarks, and I've gamed on it for ~8 hours in a row at those speeds. Until it starts slowing down in any game, 620/2006 is what I'll keep it at.
-mike
2x EVGA 8800 GTS in SLI. Running them at 634/2000 stable 24/7.
Idle temps are 49c and 54c and at load the highest ive seen is 65c and 70c on each card.
