- Feb 21, 2008
Which one is better? Don't recommend me any other cards please.
the 3650 was slower than the 2600xt in many cases.I think it goes something like (atleast for sure in terms of ages), 2600 < 8600 < 3650.
depends on the game. some games the 2600xt is faster. either way its a wash since all of the cards are really close.Then get the 8600GT. It's slightly faster than the 2600XT IIRC.
yeah I'll just get the cheapest lol 3650 is at $66
well that 8600gt is ddr2 crap. also most 8600gts cards require external power where as the 8600gt doesnt.http://www.newegg.com/Product/Product.aspx?Item=N82E16814136019
8600GT for $60
if you don't mind a rebate you can get a 8600GTS for $60 as well. Which is much better.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&Description=8600GTS&bop=And&Order=PRICE
well he said pick from those three so I thought externally powered cards might be a problem.Uh huh, well the OP didn't mention anything about being restricted my additional power. Thanks for the reminder on the DDR2 heres a 8600GT with DDR3 for $55 after rebate.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121223
the first low profile one is a pci card.
Intstead of making a new pointless thread and be referenced to here I'll just as ask here.
How would a 2600XT (w/ GDDR4) do when my max resolution is 1440x900?
Games would be Red Orchestra (usually lower res than 1440x900), and any Source based games.
The ggdr4 made no difference on that card, the gpu was the limiting factor. However, it would be perfect for Red Orchestra and Source based games.
Nexuiz runs fine at 1680x1050, all details high, all special effects off, on a 939 X2 machine w/2600XT GDDR3 (120fps+)
I have the HIS 2600XT with 512MB 128-bit GDDR3 on my E6750 and I found the card, underpowering. So I bought my 4850. Plus the card wasn't an ASUS to match all my other components so I kicked that bish to the curb.
I would agree for a modern gaming box, but the guy is talking about certain types of games. I got my 2600XT for 25AR and I simply can't complain about its performance. It surely is worth a lot more than my previous $25 HTPC card, the 6200TC.![]()
