850 watt PSU good enough?
polonyc2
I currently have a Corsair HX850W PSU and was wondering if that was enough to power a GTX 580 + GTX 260 (Core 216) used as a dedicated PhysX card + i7 980X
I think it should be OK but wanted to make sure...
my guess is you should be fine as the gtx260 will not be that power hungry, but you might be cutting it close especially if there is overclocking involved.
according to anandtech 580 SLI will go over 750W ;)
wow I never plan on going SLI/Crossfire so I thought 850 watts would last me forever and was overkill
Ahem I assume anandtech's measurements are based on DC power from the wall, so assume at least 10% less power on the actual psu. Second the realistic load on a game shows 620w. I'd guess realistically, you'll never go over about 560-570w even with dual sli GTX 580's. This is exactly why I think most people massively overkill on psus.
Anands numbers as hybry said are for SLI. So you won't be drawing that much.
The difference between their 580 sli and 580 config is 325 at max load. The 260 is 336 at max load. Add that up and you get 661 watts at the plug. THe HX850 is 80plus. so 80% of 850 = 680.
Seems to me you'd be cutting it pretty close. Not sure if all my half-assed math is correct, but I'd be concerned if it was my system/wallet.
Running a card as a dedicated physx card isn't much different than running SLI, you just might be able to run a slightly lower power draw card.
Huh what is this 80% of 850 crap. The HX850 can output 850 watts and probably far more actually.
No. 80PLus or PSU efficiency has NOTHING to do with the PSU's output capability:
What is “efficiency”?
Efficiency is the ratio between the useful output of an energy conversion device and the input. For example, if your computer uses 300W, but pulls 400W from the wall, then the efficiency is 300W/400W, or 75%.
The Corsair 850TX can provide up to 850W of power. Since it's 80Plus rated, that means that it draws at max 1050W from the wall.
Actually since it's 80plus silver, it should draw a maximum of 1000w at full load. Of course I think you can overload it a bit safely too, most high quality psus handle overload just fine for momentary periods, another reason I think people overkill on psus. It's like the seasonic 400w fanless, that thing could easily run 600-700w loads if there is enough cooling, but since it's fanless, it's rated far lower.
didn't think of it that way but I think you're right...the PSU is detecting 2 video cards and has no way of differentiating between SLI and PhysX card...so in reality I would be running SLI and would have to have a power supply that can handle it
with all the back and forth I'm still confused as to whether or not I should get a 1000 watt PSU or just keep the 850
You'll be fine with the 850W PSU. Just don't OC the GPUs.
My bad, forgot to take in account that was power draw from the wall.
Still as Danny said, you should be fine as long as you do not overclock. I would go as far as to say you will be fine as long you keep it all at stock votages, so can still do a mild overclock.
If this site recommends the hx850 for dual 480's, I wouldn't hesitate to run dual 580's with the same unit. I really don't know where some of you guys get your info.
If you keep the system all stock you should be ok but if you want to get a decent overclock on the cpu and gpus it will be your limiting factor.
